  • Replies 124
OMFG ITS FIXED!!!!! Well it's back to normal anyway. The workshop found the cause of the problem.
The NEG lead from the battery. I think before i bought the car it was replaced by the owner but they didn't do a very good job, because the wire just fell out of the connector. So that would explane why it was playing up in the past too. So the workshop replaced the wire and the very 1st run it was back up over 200kw.
Yep I would like to know the bill too. After all the suggestions and help from members, one of them really stood out that he never tried from the get go...
GO TO A NEW WORKSHOP!
Probably would have had this fixed ages ago.
I doubt another workshop would have found it easy. It's not a usual thing to pop the boot open and pull on the NEG cable. And if i did take it to another workshop i would have 2 bills to pay for and not one. I dont know how much it's going to cost yet because they are still tuning it. And where did 6 weeks come from?
i may have exagerated the 6 week part but nun the less, battery terminals / connections is one of the first things they should have checked.
how long does it take to grab the terminals and twist them and then grab the wires and tug them? 5 seconds tops.
these are the simple obvios things that should allways be checked first.
if they took this long im sure it was just a flook that they found the prob at all.
Shotter - You can doubt all you want but I guess you will never know???
Just because your battery is in the boot doesn't make it special. Even on a basic service they check your battery. And if doing work on electricals or even playing around with them they "should" have disconnected the battery first to eliminate popping fuses... or getting a nasty shock from a faulty coil ignitor holding thousands of volts.
Come to think of it this workshop sounds ace, I may take my ride on lawnmower there for a dyno run, I rekon it would top your 48kW! Especially in Rabbit mode!! lolz
Edited by Dirk Diggler
Well i just got told the cost....... F*#KING $2196
$900 for workshop time
$1100 for dyno time
and the rest covered parts used.
So not happy.
Now im not saying they didn't spend alot of time on the car. Hell i spent 2 days on it. (what a waste) And they kept saying oh we will look after you and it wont cost all that much. I dont know about you but $2196 is alot in my books. It would have been really nice for them to say "look we found and fixed the problem and the bill is around the $1000 mark, Would you still like us to tune it" My answer would have been "NO $1000 is more than i thought it would cost all up. BYE. I guess it goes to show that it doesn't matter how friendly they are or how much you think they are doing you a favour and will look after you. They are ALWAYS after money and will bend you over. So now my car will probably have to sit in there workshop for the next month till i can get the money to pay for it...
It might not be obvious for that problem - I had a mate with a very similar problem in an R33 - ended up being that the timing was completely out, but surely wouldn't someone notice!?! I for one always check the battery connections in my cars, if only for buildup of contaminants usually.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
