As title states
just wanna know if i'd need to upgrade my coilpacks for this setup
-7's (18-19psi or so)
540cc sards
wolf v400 ecu
nismo f/pump
3 1/4in exhaust , jjr front pipes, stock dumps
will the standard coils hold up for 290- 310 rwk?
ive searched everywhere but couldnt find my answer.
if anyone has a link would be fantastic.
thx
Anth.
Standard as new OEM, or standard as 10+ years old as came with the car. If it's the latter, then it's probably more a case that it's a good idea to renew the coil packs anyway. As has been posted many times, aftermarket units are cheaper than OEM.
yeah I wouldn't rush out to buy them up front. see how you go first. if the thing fires ok then you don't need them. if you get ignition break down then coil pack replacement MAY be on the cards (still investigate the other ignition related things like plug type, plug heat range and plug gap first.). always look at the cheap solutions first!
sweet. abit off topic though now. I got the car off the road for all the upgrades, and im going to change the timing belt too. I got a standard nissan belt.
Should i get a gates heavy duty one if i am going to be making 300+rwk or will the standard one do the job?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
