Hi guys,
I'm looking at buying a r34 Gtr from Gran turismo autos, i was hopping you could give me your opinion this car from its photos. As i've NEVER owned a car and am a total noob at anything mechanical all the faqs on what to look for in a car are meanless to me.
http://www.drive.com.au/used-cars/NISSAN/G...838730&pt=1
any input will be highly appreciated thanks. :D
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/
Seriously, you DO NOT want a secondhand R34 GTR to be the first car you own when you don't know anything about cars. "Driving a car for 2 hours" doesn't mean crap when there are a lot of things that can go wrong in a likely modified, secondhand turbo theft-magnet. Instead of us holding your hand through every step, the best $1000 you can spend is on a secondhand manual excel. Own it for a year, learn how cars work, then get a R32 GTS-T for a year. Then you'll be ready to fully appreciate and look after a GTR (as well as hopefully manage to secure finance).
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4351811
ummm if you just finished high school that means you have P Plates right?
P plates on a GTR
GTR with P Plates
a bayside blue GTR with P Plates being driven by a noob
can you see where this is going???
firstly cops will rape your ass like theres no tomorrow due to the power to weight thing and on p plates you will stand out like do ballz
your still a kid and would have bought GTR as a first car... you will have to give up more then your lunch money and allowance to keep that thing running
but if you can afford to buy it then i guess you can afford to keep it running...maybe
but for a first car a GTR is not the best car to get if you know nothing about cars
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4351880
GET AN R31
Hold up well in a crash, RWD, cheap in every way, and they can be treated like crap and keep on going :laugh:
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352028
wow..it looks *totally cool* from the ..photos..
gg
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352304
Hey Urgh4, BNR34's are a awesome piece of machinery fast and handling is like ur on rails. If u can get 1 great. But as a fellow Australian and SAU member, becareful this car in the wrong hands can be lethal, get used to how it drives and handles and always respect the car and other road users.
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352339
Hi guys,
any input will be highly appreciated thanks. :laugh:
never owned a car ?
ever driven a turbo car ?
yes i have actually, for about two hours audi a4 1.8t around two years ago.
holiday's great, nothing to do until uni offers
firstly urgh4...I don't know how old you are but I'm guessing your around P-Plater age. With that being said and assumed, you should not buy and own a R34 GT-R for the following reasons (IMO)
1. First you not allowed to drive it whilst on your P's. Putting up P plates on a GT-R, coppers will have a field day with you...and you are on new P plate rules. it's 3 demerit points and a maximum of $1100 fine.
2. You'll pay a hefty sum of money for insurance (let's say your 18 - it would cost 3.5k - 4k to get full comp insurance for a 18-21 year old...you would be a fool get to get thrid party)..in compaision i'm 27 and it would cost me 1.5k for full comp.
3. Service and running costs are higher than any normal car.
4. Driving a A4 1.8t for a couple of hours two years ago doesn't compare to a GT-R.
As what most people have said here...although a GT-R is a awesome car to own and drive....it's not really recommended as a first car. It's very hard now with the new P plate rules as there is many cars you can't drive. Still with something reliable and fairly cheap, get some experience on the road and then once you are off your P's then get the GT-R
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352445
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
