  • 5 weeks later...
  • Replies 129
Posted Images
you boys been hitting up st kilda pier lately?
are there any snappers around?
but then again, my longest rod is 6foot, so i dont think i'll be hitting any fair distance with that.
and lake rowville? where's that?
dunno. dont have a lift for the next time we go since everyones on red p's and passenger restrictions n shit
we usually go to the gazebo next to the spirit of tasmania at night, right thru to the early hours of the morning lol
can't take your gts4?
what rigs do you use anyway?
Edited by xALmoN
probably after dec 24, thats when the p's are booked
i honestly dont remember that rig i have, its all packed away. ive just been using a mates rod(no homo)
Fishing only here, no homo-ing, its srs bsns, will go try, half whiting okay as bait?
i usually throw a whiting on ganged hooks on one of my heavy rods just incase something big is out there
yeh no homo lol
its more of a kickback then a fishing sesh. we usually get some pizza n drinks n shit
yeh no homo lol
heading to sugarloaf tomorrow morning.
heard good things about the yellow bellies, so, hopefully they hit lures that i'm used to using.
Let me know how you go. Went to sugarloaf few weeks back and didn't get one bite. This was a Sunday morning 9-1000 with clear skies. I was using diving hardbodies and soft plastics like camo worms and minnows.
Also went on a chartered fishing boat last weekend on Port Phillip Bay leaving St Kilda Pier. Pretty unlucky - we had 12 guys and we caught 1 snapper and about 3 legal flatties. Snapper were schooling under sounder but just not biting. Perfect 25deg sunny day with clear skies, small wind. If you wanted to just land a fish though, it was incredibly easy to hook up undersize flatties with bait jigs (few guys got quadruple flatties). And we caught a lot of annoying starfish.
Well, i've heard good things about sugarloaf, so i'm gonna try my luck for the yellas or some rainbows.. and i'm wondering if anyone would like to join me.
Snapper bite more at night, that's what i've realised fishing malaysia/indonesia, and big ones at that, I will be going for snapper soon too, but prior to that, will be an evening session at mt martha for some real fresh squid, that should get the fish biting...
Any aussie salmon? They're real fun on light tackle.
  • 3 months later...
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
