  • Replies 138
funniest thing was it was on my way to work i was on my way outside the carpark LOLL :( so close yet so far.
Man that sucks!
Anyways guys, my defect is now cleared ($517 later).
Went back to vicroads and they had trouble finding the certificate again!! They eventually found it on the system, stamped my defect and said have a nice day.
No more strange looks at my car now with the yellow sticker gone. I think to onlookers, a defect sticker gives them the impression you are a criminal and/or serial killer/rapist
Hey guys,
I've been talking to Pettett via email. The guy is quite friendly and he is more than happy to answer any questions in regards to modification.
yeah... quite freindly... kinda like a guy f**king you in the ass and then giving you a reacharound
just a thought not being cocky or anything.
they only reason why the engineers don't sign off on the airbagged skylines is because it hasnt been tested ? wouldnt it be so much easier to get like a fund drive to get like 1-2 r33's or 34's and put front mounts in them and crash em and see if they change the impact and shit.
would it matter if its turbo or na ?
could get some race only skylines imported slap some front mounts on crash em with an engineer next to u or whatever then they coudl see and would sign off to all the intercoolers being on ?
just a option.
  • 1 year later...
They cant do anything if your not in the car.
i know its a bit late but had to pick up on this one. i was at trade school one day when the cops did a sweep through at lunch time, when nobody was around, heaps of people (me included) came back to find a sweet canary on the windscreen with a sealed packet that contained the list of things wrong. cops were long gone before anyone came back. c*nts (in all fairness my car was a fair nugget tho lol)
honestly everyone knows that its a defect so YOU will have to fix it. I'm not sure if you might go speak to the machnic that issued the RWC and make him pay the bill as he has passed it for RWC when the car is defected
Well mate this might come as a surprise but i actually did not know that its a defect since its the first modified car that i have ever purchased.. and none of my mates have cars with front mount intercoolers so had no idea about the hole cutting in the battery tray..
Even if i have to fix it, does anyone know of any engineers around the South Eastern suburbs where i can go to get this done?
Cheers..
Cheers..
Hi,
I really do feel your pain my friend.
Call Tony at 'TGS Muscle Cars', in Cochranes Rd, Moorabbin.
He has (had) access to a great engineer who helped my brother and I out with this same issue...a little over a year ago.
I hope this helps....you can only find out!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
