Hi Guys,
I'll be getting my RB25/30 conversion done soon, and I just wanted to confirm with you fellas some prices my mechanic quoted me for.
RB30 bottom end with Forged pistons (I forgot what brand, I'll get back to you on this one) with forged rods, all fitted and machined ready to be bolted on the head of the RB25 - $8,700
GT35R 0.82 A/R housing, 38mm external gate, with the manifold to fit thr RB30 and oil lines from GCG for $3,700
$1,300 for plazmaman plenum
$600 for contruction of new dump pipe and some cooler piping
mechanic estimated around $2,000 for labor to fit everything and tune it.
Do these prices sound about right to you guys? All up that around $16,300.
I already have the cams, injectors, fuel pump, PFC, exhaust, front mount etc etc.
Correct me if I am wrong, but isn't $8,700 for a fully forged RB30 engine a little too expensive?
yeah thats sounds pretty exspensive. $8,700
a great set of pistons should be under $1500, rods well under $1500... i'm guessing stock crank just polished or something, ACL race series bearings, mmm not % sure what they are worth to fill out a RB30. guessing a few hundred. machining costs.... and oil + water pump gasket kit..arp stud kit maybe?
mate unless you are getting the best of the bloody best thats sound rather dear.
you'd wanna be getting some high end pistons rods, rings and bearings and a high end oil & water pump.
only thing is you say "all fitted and machined ready to be bolted on the head of the RB25"
is this including the head work or is that just "ready" for you to bolt a stock 25 head on??
i'd probably go a stock internal'd rips long motor for $4300 AUD but make sure it had oil restrictors and custom drain first (haven't really looked much yet)
as well as the baffeled sump option
Sack the idea of using a GCG manifold. Buy something else. I recommend a steampipe deal from ETM (Extreme Turbo Manifolds). He makes tonnes of them to suit RB30DET's and knows exactly where things need to go on a 33 gtst to keep it all under the bonnet. Truly worth the dollars spent (and it doesn't sound like it would be that much extra judging by the dollars you've quoted.
Link is in my sig.
$3700 for a turbo kit seems pretty extreme..
My turbo setup (going on very soon) cost me:
GT35R 0.82ex - $1600 (new but not from a store, at the time the turbo new from MTQ was ~$1850)
TiAl 44mm gate - $420
High mount manifold - $150 (came off a mates car, not as quality as a 6boost or ETM but makes the numbers)
Oil/Water lines - Will be getting Enzed guy out, am anticpating ~$200
I guess if the exhaust manifold included is a 6boost or ETM item then it's not too bad, if it's a china manifold then you're getting ripped off :P
Ok, so for the $3,700 from GCG, you get the following:
GT3540 0.82 A/R
TiAL 38mm gate
High mount Xtr manifold (Xtr is GCG's in house brand)
Oil and Water lines
Exhaust flange for turbo
Gaskets and nuts.
Do you fellas think this price is reasonable?
Also, will a 38mm gate be large enough for my application (RB25/30 with the GT35R 0.82) or would I require a 44mm gate?
Cheers
i think my high mount ETM was around the $1550, including the water and oil feed and return lines made by ETM and it was also ceramic coated, as was the exhaust housing.
looking at your pricing about $2200 for turbo and gate and $1500 for the rest.
i know what i would pick any day of the week
and i would also recomend 44mm gate as a minimum bigger the better really.
GT3540 0.82 A/R
TiAL 38mm gate
Oil and Water lines
Gaskets and nuts.
Cheers
I've highlighted the bits I'd have an issue with. Also, in-house is very much the wrong word to use. They're the same as the better constructed China manifolds you can buy from ebay. They're not worth the money they charge and they don't work nearly as well as an ETM or 6boost manifold in terms of spool, wastegate flow, collector design, quality etc etc etc...
My best (and last) advice on the subject is to contact Leigh - [email protected] / +61 2 42628774 and ask for:
- High mount manifold to suit a GT35R/RB25/30/ECR33
- 44/45mm Turbosmart wastegate
- Oil and water line kit
Good luck mate.
All the best,
Adrian
Sizing of gate kind of depends on the boost you're going to run.. there's a big thread round here someone on the subject.
I believe it goes along the lines of (roughly), the less boost you want to run the bigger the gate you need (as you will need to bypass more exhaust gas from the turbine).
Short motor does seem a bit excessive..
As far as turbo set-up goes.
Mine all brand new
GT3540 1.06 A/R = $1500
6 boost manifold = $1000
Tial 44mm gate = $450
Edited by Tomek
How much power are you after? Do you really need forgies?
I would personally buy the RIPS standard RB30 for AU$3300 or spend $4300 with the head. They can probably beef it up a little if you want and will cost u a lot less than your quoted $8000+
I am aiming for 370 + rwkw.
So forgies are a must.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
