So this morning I finish washing my car and knew I was low on fuel so I drove to the closest BP to fill up and I turn in and all the pumps have 'Sorry Out Of Order' signs on them...
I drove to another BP hoping I wouldn't run out of fuel and the same deal there!
I asked the guy why there wasn't any ultimate and he said something about BP missing a shipment or something?
It's the only fuel I use so I decided I had to put in atleast 10$ of normal premium and then decide which fuel to top up with later on..
Bit confused at which to go for at the moment.
Vortex / V-Power (if its still around?) / The United one.. / Mobil Synergy 8000 or whatever its called - or another!? if any?
Sure the question of which fuel is 'best' has been asked many times before, but id like some 'current' feedback before I head to fill up >,<
https://www.sau.com.au/forums/topic/251768-bp-ultimate/
  • Replies 41
I had the exact same thing happen to me on Tuesday night, went to my closest BP and all ultimate pumps were out, went to the other BP bit further down the road and the same thing!!
Also a friend in another area went to her BP that same night and it was out. I didn't ask anyone at the station what the story was but I guess you have and now we know....
Thankfully I was not too low as I really do not think my car will run on regular and I dont want to have to fk around with octane booster etc...
I will fill mine up with Mobil Synergy 8000 either today or tommorow as it is the next best petrol in my opinion plus I seem to get better fuel economy out of it...
Haha, I can't believe BP have run out of Ultimate (even if its only in this state)... thats pretty fkn bad!
https://www.sau.com.au/forums/topic/251768-bp-ultimate/#findComment-4357567
They've been like this since atleast early this week... And the servo I went too had regular at 95cpl :)
I use mobil when there is no bp, but I get worse around town economey, and I won't touch shell, never runs well in this car and never did in the datto
https://www.sau.com.au/forums/topic/251768-bp-ultimate/#findComment-4357904
ummm i decided to try bp ultimate instead of my usual vpower and there was no difference in performance/powerband etc
oh and fuel economy was negligable, 10-20k difference a tank.
i noticed my knocks went down about 4 spots but then again it was a cold night, im sticking to vpower or ultimate but im reluctant to try mobil/vortex
https://www.sau.com.au/forums/topic/251768-bp-ultimate/#findComment-4357911
Would a car that is tuned with v-power run better on v-power and vice versa? Is that one reason why some people including myself see differences and some dont? My car was tuned just after filling up with mobil 8000 and now it runs better on mobil and bp. Dont get as many km's out of v-power or united etc etc.
https://www.sau.com.au/forums/topic/251768-bp-ultimate/#findComment-4357917
I spoke to the guys at work about this and as of last week BP were running very low on Ultimate stocks so it is possible they have not yet got a shipment hence the servos are running out. I work for Reliance Petroleum (regional BP) just so you know.
Oh and I also fill up with Ultimate because my car likes it (I don't get it cheaper or anything cos I work for head office either :D ), VPower runs shite in my car, 8000 and Vortex are fine
https://www.sau.com.au/forums/topic/251768-bp-ultimate/#findComment-4358832
It was a while ago but I am sure my firend talked to a tanker driver who was filing up the stations tank with BP Ultimate. The driver said they filled the tanker up with BP Ultimate at the same place the tankers filled up with Mobil Synergy8000. So it would mean they are the same thing. Obviously I can't confirm it any more than that but it wouldn't surprise me if that was the case. I've heard a few people mention they get less slightly knock with these two fuels over Shell and others.
As far as better economy goes, surely you can't really try and compare a difference of 20km. That could easily be influenced by the way you fill up each time and it would only take a few more squirts of the throttle on the one tank compared to the other.
Edited by Fry_33
https://www.sau.com.au/forums/topic/251768-bp-ultimate/#findComment-4358869
+1 i use bp/mobi/shelll
although i do notice a more stable idle with ultimate
Thats probley why I use BP too, hehe!!
I haven't filled up yet cuz I haven't ben driving much lately but if BP is out then I just puts some Mobil Synergy 8000 in.
https://www.sau.com.au/forums/topic/251768-bp-ultimate/#findComment-4359305
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
