Did a firmware upgrade on the vipec that solved the misfire problem i was having a few pages back.
Went back for another tune it made 486rwkw on e85. Engine is rb26, -5's running 26 psi
Can any tech heads tell me how to upload the dyno graph as its over 2mb ??
Edited by Mark-32
I'll PM you my email and i'll do it for you if you aren't sure how to
Or, you can sign up with a hosting place like photobucket and host it there then use the IMG tags to embed into this thread
EDIT: Here they are
that is a huge number for -5's even on e85....
keen to know spec list too
I was suprised myself but I have dyno papers from when it was first run in on dyno on 14psi, then tuned on 21 psi on pump fuel, then now on E85.
All the dyno runs today were in 5th gear as 4th would just bag the tyres.
Spec list of what i can remember in no particular order is-
RWD Rb26 conversion in an r32gtst
r33 5 speed
hi octane 11 litre sump (rear head drain, nismo oil air seperator going into main catch can that drains to sump.)
1mm restrictor
2860 -5s
big trust intercooler (unsure of exact dimensions but its over 100mm thick and pretty huge)
exhaust is stainless split dumps into 3 inch y pipes into a 3.5 inch sidepipe no mufflers
cams are tomei 260 10.8mm lift??
nitto/je pistons
nitto I beam Rods
Arp stud kits throughout
balanced and blueprinted
nitto 1.2mm head gasket
vipec v44 ecu internal boost controlled
fuel system is 1v 044 lift pump
2x 044 external out of surge tank feeding hicas lines
greddy twin entry rail
aeromotive fuel reg
ID1000 injectors
Edited by Mark-32
Eyebrow's are raised by that result... Seems to be a bit on the generous side?!?
What would correction ratio be between AT 9deg and IT 21deg?
+1
With probably the strangest boost curve ever... And -5s hold 26psi @ 8000rpm without any drop off in torque!?!
This is certainly odd.
I assumed the figure was so high as its rwd only?
To begin with the boost was at 24psi but the boost curve flattened off aswel as the power curve around 6500rpm making consistant 430 odd rwkw.
The tuner asked if i was happy with that and I said i wanted to add a litte more boost at the end of the rev range to see if the power curve would continue upwards in the direction it was heading. He then snuck more boost into the engine up top and thats what happened.
Im stoked with it, haters are guna hate either way but it is what it is.
  • Like 1
The tuner said it was cylinder pressure that would kill the engine and it seemed as though it was struggling for spark as you can see from the dip in the power curve that looks like wheelspin after 5500.
The tuner had to adjust the boost controller in that way so it would run properly.
I have a crappy photo of the dyno screen from where he was adding more boost. It went 420 on 21ish then 460 odd on 24+ then made 486 up to 26psi
I just dont know how to upload it as its over 2mb. I can send it to someone if they can do it for me?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
