hello yes i have searched the forums
.33 gtst rb25det
.modified to ~220rwkw, 18psi.
.all supporting mods inc. toshi remap
last night the car developed a strange problem hesitating, stuttering, coughing low down in the range (up to 4000rpm). it felt similar to the car running out of fuel, or an air leak. checked both these things, cant rule out a small boost leak, but i am puzzled because once the turbo comes on boost the car runs fine, and still swallows the tarmac like it always has. even downshifting and booting again, the car works great as long as you keep it on boost.
it seems that whatever the problem is, boost fixes it.
to my understanding, that rules out ignition problems, since i figure they would get worse under high boost. (though im about to change the plugs). same goes with a boost leak, which would probably get much worse under high boost.
my old man seems to think it might be the fuel filter, a blockage of some sort. i guess maybe when it comes on boost it overcomes this blockage? another theory i have is the o2 sensor, though i have little understanding of them, it seems to be a common problem in my various searches through the forums.
any ideas?
i figure a fuel filter would be about $20, and an o2 sensor <$100 so ill prob change them if i cant figure it out soon.
cheers,
mitch
https://www.sau.com.au/forums/topic/251829-bizarre-cruising-problem/
If you have the stock ECU (nistune'd or not), flip the R33 service manual ( http://www.importworkshop.com/nissanskyline.html ) to the self diagnosis section, code 55 is all good, anything else just look up the code and it should tell you what's the problem
I believe i had the same problem, i thought i was looking at new coils but i merely took the coil pack loom off and straightened it out a bit and it was fine!
Just check all your connections for crap and full connectivity.
replacing the fuel filter made a massive improvement! wasnt overly difficult to do either, so ill def be doing that every 20k or so. the old one was filthy, no idea how old it was... potentially 100 000km.
still to change the plugs, cant locally source anything in a 7 heat range ffs!
Hey, I have a issue with my RB26. After it warms up, or after a squirt. Once the cold air circuit closed loop has opened. It started off really intermittient. Now it is getting worse. Shutters/hunts and stalls. Started off happening on the highway where it would be driving fine untill it starts surging/misfiring, feels like ECU cuts ignition and fuel, and it stalls, restart/jump start then it will be fine for a little while. I managed to get consult plugged in, and logged data stated faulty Mass Air Flow Meter code## (mind you this could of been from past unplugging of sensor, from having to clean oil out of sensors with contact cleaner (Co2) was causing simuliar problem earliar to this) have now pulled off most of piping around turbos down to housing, now clean!. I can see a little puddle of really sluggy oil (amount of a 5c piece) in bottom of back turbo housing, was also a small amount in front housing (blowback from running 12 psi now maybe) installing a catch can this time. Front turbo shaft feels ok no oil around it, can't reach back turbo shaft or get any further visual inspection of it, apart from a slight amount of greasy old oil around outside of rear turbo. I am thinking it is either of many of things after been reading a few posts.
Faulty - Mass Air Flow Meter sensor/s (enough, was enough).
Faulty - Air Temperature sensor.
Faulty - O2 sensor
Faulty - CAS.
Faulty - TPS. (allways had odd idling 900-1200 rpm depending the outside temperature)
Faulty - Fuel pump (pressure).
To much oil in the system (intercooler, plenium, AAC valve, air regulator). - not fun to get at on a R32!
Turbo said enough, is enough.
Or maybe even a injector/s or even possibly a ECU giving up. If anyone can help to my cause it would be much appreciated.
Thanks WhiteBeast!
i reset the ecu and it helped greatly, still did it once on the freeway. i have no idea, it seems totally random when it happens, the rest of the time the car goes hard. much better now though.
Sounds like ur AFM could be starting to play up. Might just need cleaning properly. Mine did this initially as it was playing up intermittantly, & boosting did seem to help. But then i discovered that mine was completely f@#$%d 5 mins later lol. I reckon try this, as it does seem to emerge then disappear randomly.
thanks i will take that on board. i just put in a z32 maybe 6 months ago, so itd be rather annoying if it was that.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
