Not a Skyline I know fella's but someone may want to come across to the dark side.
Item: 91 Cressida Glx 1JZ Twin Turbo
Item Condition:Good
Price and Payment Conditions: 8500 ono No Swaps thanks.
Contact Details: PM or 0407332944
Considering selling my car as I've found another one I would like to buy and the wife wants a car with airbags, abs etc for our baby on the way. The car has 14XXXX kms and is a 2 owner car before I bought it. I've upgraded evrything on this car including:
- Amistad 3 piece 18*8 & 9wheels with yokohama 235/40 and 255/50 tyres
- KYB suspension brand new Rav4 front shocks and Supra rear with kings springs, upgraded rear sway bar
- R33 brake calipers on BA Faclcon Discs with Project Mu pads on the front a new rear pads
- 1JZ twin turbo engine from JZX81 Front cut
- Titan adjustable cam gear on exhaust cam
- custom dump pipe into 3"system with genuine Metalcat
- Walbro fuel pump
- SAFC and SITC combo
- 600x300x75 tube & fin intercooler
- Grande LSD
- Momo woodgrain steering wheel
- Pioneer head unit with clarion splits in the front 6"kenwoods in the rear and 2x10"clarion woofers in a box in the boot powered by a kenwood amp
More info available in my members ride thread:
http://www.toymods.net/forums/showthread.p...highlight=bogan
Here are a few pics:
The car drives beautifully and I only drive it on weekends as I walk to work.
The only things that detract from the car are the minor trolley dents in it and some scratches which you can see up close so it's not in concourse condition but its pretty good for a 17 y.o. car!
Just fitted some new turbo's on the car last weekend.
The wiring was done professionally by Mos so you know thats done right and this car is registered with the 1JZ in it but other states may need engineering but I think once it's registered here it may not so it would be best to check.
I am chasing $8,500 for it which is pretty sharp for a car with this amount of time and money spent on it.
Cheers
Rich
0407332944
https://www.sau.com.au/forums/topic/252005-twin-turbo-cressida/
  • 1 month later...
Ok need to sell this now as I've just bought a JZX90. I'm willing to strip some parts off the car to reduce the price such as the wheels which I will put on the 90 and a few other bits and pieces. I will put some 17's or maybe some GTST 16's on the car and will consider somewhere btw $6 and $7K depending on what you want brakes , cam gear, stereo, SAFC/SITC combo etc. Basically you can have a series 2 1JZ cressida with a genuine 144K on the clock for less than it costs to buy and do one yourself. Hit me up with offers!!!!!
Cheers
Rich
0407332944
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
