Is it possible to replace the head deck in a 2003 stagea, it seems to be integrated with the AC system, etc.. appreciate any advice as current unit is dead and I'd prefer to have a more modern cd player/ipod control unit in the car..
Cheers
EDIT: All I really want is to be able to plug a 3.5mm jack into my iPhone.. that would work fine.. but can it be done?
Edited by Adam NZ
https://www.sau.com.au/forums/topic/252324-head-deck-in-2003-stegea/
Cheers
?? which model?
I have a 2003 rs four and have recently replaced the standard (crap) head unit. is it just a single DIN unit you have?
the only difference from any other car is that you need an antenna adaptor - but most audio shops have these.
Cool, thanks for the responses guys.. will snap some pics of the dash - but basically it's a slot load cd (6 disc changer) in the dash - all seems to be integrated, but I think it's a single din.
Does that mean I can simply connect a 3.5 cable from my iPhone to the antenna signal and get a good qlty connection? Cause I've never found a decent quality fm transmitter for the iPhone. Would certainly make for a decent cheap solution!
Cheers,
Adam
do you have navi? if so that makes life easy. OR if you can find someone over that way that sells connects two or Neo products then you can get control of the ipod you have.
as for replacing it, that is a $700 AUD exercise in panels,parts and interfaces (assuming bose here.)
i went to look at another Stagea m35 for sale today. the ad said Bose stereo, but it had no subwoofer in the spare wheel and it had the single DIN unit under the three gauges with no branding on it whatsoever.
Can someone post pics of the bose system please.
then it wasnt a bose item. trust me you do not want the bose audio in one. if the unit breaks (and they do quite regularly.) then its a massive exercise to change and quite expensive to fix. the CD stacker is $600-700 to repair properly. if the unit dies it takes the AC control system with it.
what you are looking at now is a better option.
which headunit is the Bose unit? the integrated one or the single DIN one which sits under the 3 gauges?
Can someone post a pic of the Bose unit please?
integrated dash with bose written on the tape door.
cheers, i'll take your advice as i keep looking. i really like the 3 gauges anyway so i like what I'm hearing.
the car I saw today had 53000kms, 2002 250t RS4 in silver, from a dealer just complied so 12 months rego, 3 year warranty (24/7 aftermarket warranty). no options, cloth interior, no sunroofs, but retains xenon lights and has the tv (birdview/xanavi) $18k.
Has to get somethings repaired on it before they will sell though, like a sensor for the AWD system and the TV won't slide back into the dash so i'm not sure whats going on really. Its a bit rough around the edges, paint isn't perfect and it has a few marks inside on the dash.
I think i'll keep looking but its good to see whats out there.
Good idea.
FYI Bose
Standard (but with Nismo gauges)
Edited by iamhe77
could you even option the bose system on an RS?? no RS had integrated stereo AFAIK as it took the place of the gauges. only RX, ARX and AXIS had tht option
I've never seen one setup that way from factory. that said I have seen them with non bose integrated dash panels. cannot remember what version it was though.
how come the RX come more 'optioned up'? aren't they simply the jacked up 'outback' version with flares?
I would love rear air con vents although I can live without the electric, heated leather seats and bose (by the sounds of it) but the grey flares on the RX really turn me off.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
