hey guys... braught my new stag today... pickn it up in the next wk or so!
im going from sydny to adelaide in it... does any one reccomend/curse any particular route??
what do i need to take with me
tools gps, laptopwith internet for sau if needed :(
coolant oil
i rekn thats bout it... ive got raa premium so we should be set i rekn...
btw its a 260rs :D if that helps
https://www.sau.com.au/forums/topic/252440-my-new-stag/
  • Replies 54
a spliff or two? nah, thats about it think youve got it covered. just cash for emergency I suppose
so a 260 eh? NICE one !!!! pics / links to 4sale of the car youve bought ?
cheers
still waiting for mine; since start of dec its been in the shop.
https://www.sau.com.au/forums/topic/252440-my-new-stag/#findComment-4366246
Sydney, Wagga, Narranderra, Ouyen, Adelaide.
(i hope i have that correctly listed)
that route was a good trip about 10 years ago approx 13hrs with racing pitstops for fuel and greasy food.
i was even thinking mayb threw melb them home? so i could atleast have decnt road most thaway
nup :( gna b unseen till the next stag cruise :D
https://www.sau.com.au/forums/topic/252440-my-new-stag/#findComment-4366418
Thats actually probably a good idea. But i don't fancy your chances getting them thru airport security on the way there.
Maybe buy som bottles of octane booster at your first pitstop in case you can't find pulp in woop woop.
Take 2 jerry cans lol.
but really, take 2 jerry cans.
https://www.sau.com.au/forums/topic/252440-my-new-stag/#findComment-4368333
Dont worry,
We'll be stopping of at supercheap, repco ect ect... before we leave syd to get some supplies (coolant, oil and jerrys)
Things im thinking that will be put under most strain is the cooling system and maybe some of the ancillary belts. Might buy a spare of each belt for the drive home would suck if one snapped in the midle of f**k nowhere ayy!?
thoughts?
https://www.sau.com.au/forums/topic/252440-my-new-stag/#findComment-4368388
i drove mine back with the girlfriend from qld, somehow managed to work out perfect that everytime we needed fuel we came across a servo. just lucky i spose. the drive was easy and comfortable, just watch out for wildlife dependant on the way you go and the times that you are driving
https://www.sau.com.au/forums/topic/252440-my-new-stag/#findComment-4368398
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
