:D
Need better cat-converter, this one is holding back 10kw and resulting in loss of boost at top end.
More tuning management, such as a fresh remap even (will speak to Toshi), would result in using more fuel top end and another 10kw.
Then the additional injector setup & tuning. Maybe better FMIC with a Greddy plenum.
206kw being held back tho.
Car:
1997 Series 1 Nissan Stagea RS Four Station Wagon
100,000kms, Automatic, RB25DET engine, Attessa awd
Silky Snow Pearl, Dayz body kit, twin sun roof
Fully serviced & tuned, fresh fluids throughout always, including diff / engine / gearbox / attessa awd / power steering / radiator / brake fluids, 100”km service including new water / oil pump, new belts, exhaust studs etc
Engine:
Ryco Z201 fuel filter & Ryco Z145 oil filter
Motul TurboLite 10w/40w engine oil
Greddy remote oil filter relocation kit
Davies Craig automatic transmission oil cooler upgrade kit, braided oil lines
MV Automatic shift kit & auto service kit
Koyo Radiator 24mm-thick upgrade kit
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-gruve spark plugs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Aerospeed adjustable exhaust cam gear pulley wheel
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch Just Jap Racing stainless steel single dump pipe system (turbo to cat)
3inch Racing Technologies metal cat high flow catalytic converter
3inch cat-back exhaust system with Kakimoto GTR Racing hi-flow straight-thru muffler
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Apexi Super Induction pod filter
Apexi 'Hybrid' front mount intercooler, tube & fin and bar & plate, with custom return air feed pipe kit
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Apexi Profec B spec-ii dual stage Electronic Boost Controller, set to 1bar and 1.1bar
HKS heavy duty 14psi turbo actuator
Sliding Performance water/oil cooled 360degree journal bearing Hi-Flow Turbocharger, Pirtek braided oil line
Rated 250rwkw at 1bar, 3yr old 15,000kms perfect condition.
Toshi remapped ECU chip
TW Engineering head port & polish job, fully rebuilt including:
* Cometic intake manifold gasket, intake collector gasket, & exhaust gasket
* Cometic Head gasket 1.2mm x 87mm
* ARP head stud kit
* EPP Intake & Exhaust valve seals
* EPP Intake & Exhaust valve seats
* EPP Intake & Exhaust valve guides
* EPP clear cam gear timing belt cover
* Tomei oil gallery restrictor orifice
* Tomei hi-lift valve springs ~8.8mm
* Tomei 256/256 poncam camshaft set
* Gates Racing timing belt kit incl. tensioner and idler
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphic 17” x 7.5” +40offset rims with Hankook K104 Ventus tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, Front and Rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player + usb-mp3 adapter
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit
Car alarm
Parts to Fit & Tune – Boostwerks:
2x 700cc Sard injector external intake manifold setup
HKS AIC IV additional injector controller
Q45 90mm throttle body
Greddy Q45-RB25 adapter kit
* Greddy plenum, fmic & 4"cat ? :cool:
https://www.sau.com.au/forums/topic/252849-finished-sort-of/
  • Replies 58
yes
yeah the plenum/throttle-body is mainly a pipe dream.
the ecu is still holding it back, as is the cat converter (tested), perhaps the fmic as well
runs so nice tho, but yes another 20kw to find :cool:
:D
the intercooler is only 380mm long, made for 180sx sr20 & rb20's
although I doubt I'll be touching anything for a while, the only thing to look at is the cat
feels awesome on road, like a punchy 3litre, purrs while idling, and of course the shift kit is loving the mix!
very very nice shifts, ecu is km unlimited and set for a higher redline, doesnt miss a beat from 3000rpm onwards
happy with the mv auto shift kit without doubt, very happy with the engine too ! probably need a gt2835 tho :(
went for a 2hr 200km spin over my old Hills roads
wow, very quick. the cams are the beezkneez
such a different engine
its an awesome package, heaps quick in the Hills unbelievably so ! :P
You seem to have a very improved package. You have bought a lot of gear and with the port and polish i would think you would expect quite a bit more power.
You have identified a restrictive exhaust and that should be straight forward to fix.
i think you need two things:
1. A computer
2. Some serious dyno time (for example do you need the adjustable cam gear with your poncams/ Has someone tried a number of different settings?
On the question of the computer the latest Link is suppose d to be able to handle autos -i haven't enquired yet but they have a lot of computing power and inputs and outputs. There are tuners and tuners and I am sure that just as In NZ there are some who can get a lot more out of the same car as others. There is no substitute for proven experience and there are a few who seem to stand out such as Anthony (Guilt Toy) or Dr Drift - you could try to talk to a few of their clients or perhaps there are others closer to you ( I am not familiar with the Aus scene) but 240AWKW should not be out of the question unless it is just the turbo holding you back. Anyway all your mods are sound and it is good that you are feeling the improvements in the driving.
In Aus the ViPec seems to be taking off, and Trent at Status here in Vic seems to love them, they are pretty much the same as the link... and should be a fair bit better than his current mail order remap.
Nice! Next cruise I'll have to come for a ride!
Ive got everything here for 240awkw for sure
got to open up the cat converter exhaust restriction, there was a proven 18kw increase on the dyno with it off.
so, must sort that out asap.
and yes a properly ecu setup is also a must
but, so is a proper ball bearing garrett turbo, probably gt3071r-iw
as it is, with piggybacks and mail-order ecu plus Slide cheap hiflow, its doing all right I reckon.
top gear top speed .9bar and the engine is only at 3000rpm tho
in 3rd gear above speedlimit it really is punhcy, 3000 up thru 6000rpm is sweet as
can only imagine what a good turbo would be like, could see 40kw gain from 80kpmh plus Id say
the current turbo is letting it down above legal speeds, tested last night on various runs
under 120kmph and the machine is a street-dog!
there are various Pros and Cons to the current setup
the ecu chip has scope for more fuel, plus have the 2x700cc sard setup with HKS AIC-4, I reckon a big tuning session and a better turbo / catconverter would see that 235awkw with these current piggybacks. so many options, so little money. Once a proven auto ecu is out I'll sell all my electronics and go that way. Wont lose out $-wise in the exchange so its all good
slide turbo sell $600 buy gt3071r $1800
apexi safc / sitc / Toshi ecu sell $1000 buy ecu+tune $2000
hks aic-4 + 2x700cc intake setup sell $500 buy S15 JDM 480cc $500
decat $-
so, need another 2500 to sort it out - in the long run
will enjoy it for now, and play a bit more later on. out of budget and frankly very happy with the 36,000$ motor vehicle Ive built up over 4yrs (cost 18 plus mods,tunes,services) edit: 1k gear not fitted
WHERE DID YOU GET YOUR CLEAR CAM COVER FROM?
That was the first thing I thought when I saw the pictures too lol!
Glad to see you got her back *at last* Tangles... and Boostworx have done another good job :) How are the turbo oil seals?
206kw is pretty damn impressive for a series 1 auto. I'm only making 185 on my series 2 with a full 3" exhaust/custom split/dump pipe and a hi-flowed neo turbo. Tuner said that it was the auto 'box sucking up all the power. Although I am running the stock side-mount intercooler.
Thinking about some poncams now... low - mid-range power sucks atm. and that beast of yours sure did sound smooth at 4,000 revs :).
Edited by DaveB
thanks heaps!!
ahh, 225kw without the cat, ;) ... cant sleep, thinking:
going to hammer thru a 3" perforated tube thru the cat converter, to free up a bit of power
going to sell all the parts I still have hold of here, that will net a total of 1grand
once thats done I will sell the intercooler for $450 and the Slide turbo + oil line for $550 (turbo is perfect)
then I'll buy a larger fmic 600x300x76 (not return feed) complete ICS-Performance ecr33 kit for $350 and a garret GT3071r-iw for $1600 with lines
a tube will take the air from front left up into the pod filter, thru the hole currently setup for the return feed fmic
better induction over the 390x280x76 apexi return feed cooler, better flow to the pod filter from the snorkel + air-dam Dayz front bar
the cat converter will still 'perform' with a perforated pipe thru the guts, as gases will still be able to flow and mix with the internals while being less restrictive than current
the turbo will be 40kw better
and then it'll be tuning, and more tuning,
so as it is got to get some parts sold, such as :
NEW rb25 to greddy plenum using stock throttle body adapter kit - $100
q45 90mm throttle body - $150
2x700cc Sard intake manifold + HKS AIC IV addition injector controller - $500
stock cam shafts - $100
stock cam gear cover - $50
stock exhaust cam gear pulley - $50
stock turbo dump pipe & stock front pipe $50
& then the intercooler then the turbo
went for a rip again last night, so so awesome!! if you get poncams get the 8.8mm spring lifters plus a head gasket too. worth it definately.
I went for arp head bolts as well, plus obvioulsy decked out the head while it was all off. Poncams, springs & head gasket would probably suffice tho.
very very smooth, needs a better setup as outlined above for the tru potential to show.
thanks heaps!!
At the power levels you have now your car will be going very well indeed so no need to do without food to get the last few kw but gutting the cat wil be free and result in a significant increase. At the year and mileage of S1 and most S2 Stageas the catalytic converter will be adding to emissions anyway rather than reducing them.
If you do go the whole hog ( new turbo) you will end up with (allowing 70kw for transmission losses) 310 to 320kw - serious power in a package with the Atessa, suspension and brake mods to handle it. An inspiration to us all!
Yeah that sounds awesome tangles, I like your thinking! How ironic that the cheapest cat' is also the highest flowing ;)
Would you mind passing on where you can get a 3071 and lines so cheap? I priced lines and fittings for a couple of options when I was researching the cost of my hi-flow and anything garett/hks/non-standard always cam out around 2,000 somewhere, hiflow was the cheapest I could find. ACS do their 3071 core upgrade for the standard turbo but that's even more expensive ($2,200?) and I heard, laggy.
$350 is a cheap intercooler option. However I have been considering, for similar money, a liquid-air intercooler setup; the lines would be shorter and potentially *much* shorter (depending on how much work I want to fit it) and the cooling capacity would be much better than a fmic, and should be much lower pressure drop too (say, less than half a PSI - perhaps as low as .2 PSI?) This is purely speculative... have you thought about liquid->air?
thanks for keeping us posted... it's always a good read :)
edit: PS What else did you have done to your 'decked out' head - just port/polish? Is that why it took so long in the workshop?
Edited by DaveB
looking thru things at the moment
no rush, but will be upgrading the turbo and net the mid-240kw power/ phat~torque levels Ive been aiming for
not shitting on this slide highflow, a good little streeter like a journal knock-off version of the hks 2530, but all-in-all fricken good for $600 (oil/water/360deg~thrust/Stage-2 hiflow)
but a better turbo would surely see 30kw gains through-out the midrange and top end
something from garrett like the gt2876r (aka hks 2835), most likely a gt3071r (aka hks 2540), or gt3076r. hks 2540 looks the goods TBH.
cheers. +/-250kw would be very nice wouldnt it. ;)
: no rush tho :
got to enjoy it as is. went out again thru the hills last night, thats 3 runs now.
top gear the turbo hasnt the puff to produce more than 3500rpm
3rd gear rips thru past 6500rpm and sounds glorious
1st gear isnt really needed, and 2nd is proper for corners :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
