  • Replies 41
well you won't be maximising the efficiency of your mods.
as RedlineGTR said, standard ECU isn't exactly suited to run anything out of it's stock specifications by too much...especially if you're running aftermarket turbos...
SAFC2 is sorta like the entry level fuel adjustment computer...but something like the PowerFC would be much more versatile
rob, i've got 250rwhp and my injectors (stock) are at 70% (according to powerfc) duty from memory. Is there a ratio/relationship between power and injector duty?
When I end up putting the Z32AFM on I want to up the boost to 1.1bar or so in an attempt to reach 280rwhp without having to get injectors (I have a adj. fuel reg and 600hp fuel pump).
Mark
If you have a small budget, you could stick to the stock injectors, get a bigger fuel pump like a bosch 910 (both gtst-vspec and I run one of these) and use a safc2. Granted you wont be able to play with your ignition maps, you will be able to adjust fuel in and out. The car would still be quick on the road, but if you've gone to the trouble and expense of a bigger turbo you really should put in the full ecu to compliment it.
thanks for the info rob77 & GTS-t VSPEC !
yeah i'm kinda on a budget right now because i dont want to spent too much on the car. I would still need something to control my fueling, so definately an SAFC2 is good enough for that.
I have a turbo & intercooler at the moment in my room.
The things i have to get are,
- fuel pump
- safc2
- intercooler piping
Does the adjustable fuel regulator do much difference ?
Do you think I should put in an adjustable cam gear on the exhaust side and retard it by 4 degrees ?
Thanks again all of you for your contribution ! :P
I did the cam gear, and in mine it made phuck-all difference, but others have reported gains.
Depends what power you plan on gettig, anything more than 340rwhp on stock injectors will require an increase in fuel pressure.
Rob and I both use the bosch 910 fuel pump, his is in-tank, mine is external.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
