hi there just installed my new turbos (thanks kudos Motorsports)
the 02 sensor holes onmy new dumps are for the large size o2 sensor and my 32gtr has the smaller size
the ones that were on the factory dumps did not fit not sure why
any way i can sort this im currently running no o2 sensors
how do i sort this?
https://www.sau.com.au/forums/topic/252989-02-sensor-reducer-nut/
Sounds like someone has put R33 O2 sensors on at some point if your car has smaller ones.
I remember getting a reducer nut with my Trust Dumps, but not totally sure where you would buy them aftermarket off a shelf.
Perhaps a hardware store?
if your really worried just have the old nut cut out and a new one fitted
or swap back to factory o2 sensors
or get R33 dumps and sell R32 ones
but until you've tried a hardware store (a big one) i wouldnt worry too much
yeah but was a bit futile as the dumps are on the car are blanked off
and im not sure what outer bolt size to ask for
i did see the reducers there and there should be one that i need
i dont have the o2 sensor here with me either so i cant tell them that either
ill have to wait till next weekend now
oh well live and learn lol fail x 100000000
is it possible i can use a 33 gtr o2 sensor as per this thread?
Having the same problem, hence why i started my own thread!!
Just to clear things up. Both R32 and R33 GTR's use a sensor made out of titania. Both use a three wire plug and both have a voltage range of 0 to 1 volts. This is why the Power FC is generic for both in regards to the O2 sensors. The ONLY difference is the thread size of the sensors.
R32 GTR: 12mm thread
R33 GTR: 18mm thread (spark plug thread)
Now, both use the same plug formats as well i believe, which differ from the front one and back one.
The factory serial numbers (genuine nissan) for these items are:
R32: Front - 22690-05U21 (Flat 3 wire plug)
Rear - 22690-05U22 (Square 4 pin plug)
Alternatives - front - NTK OTDF-P1P
rear - NTK OTDF-P1L1
R33: Front - 22690-24U02 ($209 from Metro Nissan Brisbane)
Rear - 22690-24U01 ($212 from Nissan)
So as you can see, buying genuine nissan is just being A$$ raped, hence why i am looking for alternatives.
Tony
as they seem to be fatter and should fit perfect?
I bought xforce dumps and they came with the adapters, so you could try an xforce stockist. BUT with these adapters the o2 sensor is well back from the exhaust flow as it holds the sensor quite far out. I'm concerned this will affect its operation...
thanks for that
i pm'd just jap and they happen to have what i need in stock
but thanks for the responses its awesome being part of a community that work together
p.s went to 3 exhaust shops and coventry fasteners and 1 smaller hardware store and also a reece plumbing store today
none of them had anything that i needed lol
at the end of the day i could have bought a bolt drilled a hole and tapped it
p.s again upon reserching it seems 32 sensors have diff voltages compared to 33 - 34 so i didnt head down that path
im not running any o2's at all at the moment
people said id be having economy issues etc but the car runs fine and uses the same or less fuel than before i removed them?
but better to have them in than not at all
great example pic btw!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
