hi there just installed my new turbos (thanks kudos Motorsports)
the 02 sensor holes onmy new dumps are for the large size o2 sensor and my 32gtr has the smaller size
the ones that were on the factory dumps did not fit not sure why
any way i can sort this im currently running no o2 sensors
how do i sort this?
https://www.sau.com.au/forums/topic/252989-02-sensor-reducer-nut/
Sounds like someone has put R33 O2 sensors on at some point if your car has smaller ones.
I remember getting a reducer nut with my Trust Dumps, but not totally sure where you would buy them aftermarket off a shelf.
Perhaps a hardware store?
if your really worried just have the old nut cut out and a new one fitted
or swap back to factory o2 sensors
or get R33 dumps and sell R32 ones
but until you've tried a hardware store (a big one) i wouldnt worry too much
yeah but was a bit futile as the dumps are on the car are blanked off
and im not sure what outer bolt size to ask for
i did see the reducers there and there should be one that i need
i dont have the o2 sensor here with me either so i cant tell them that either
ill have to wait till next weekend now
oh well live and learn lol fail x 100000000
is it possible i can use a 33 gtr o2 sensor as per this thread?
  Quote
Having the same problem, hence why i started my own thread!!
Just to clear things up. Both R32 and R33 GTR's use a sensor made out of titania. Both use a three wire plug and both have a voltage range of 0 to 1 volts. This is why the Power FC is generic for both in regards to the O2 sensors. The ONLY difference is the thread size of the sensors.
R32 GTR: 12mm thread
R33 GTR: 18mm thread (spark plug thread)
Now, both use the same plug formats as well i believe, which differ from the front one and back one.
The factory serial numbers (genuine nissan) for these items are:
R32: Front - 22690-05U21 (Flat 3 wire plug)
Rear - 22690-05U22 (Square 4 pin plug)
Alternatives - front - NTK OTDF-P1P
rear - NTK OTDF-P1L1
R33: Front - 22690-24U02 ($209 from Metro Nissan Brisbane)
Rear - 22690-24U01 ($212 from Nissan)
So as you can see, buying genuine nissan is just being A$$ raped, hence why i am looking for alternatives.
Tony
as they seem to be fatter and should fit perfect?
I bought xforce dumps and they came with the adapters, so you could try an xforce stockist. BUT with these adapters the o2 sensor is well back from the exhaust flow as it holds the sensor quite far out. I'm concerned this will affect its operation...
thanks for that
i pm'd just jap and they happen to have what i need in stock
but thanks for the responses its awesome being part of a community that work together
p.s went to 3 exhaust shops and coventry fasteners and 1 smaller hardware store and also a reece plumbing store today
none of them had anything that i needed lol
at the end of the day i could have bought a bolt drilled a hole and tapped it
p.s again upon reserching it seems 32 sensors have diff voltages compared to 33 - 34 so i didnt head down that path
im not running any o2's at all at the moment
people said id be having economy issues etc but the car runs fine and uses the same or less fuel than before i removed them?
but better to have them in than not at all
great example pic btw!
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
