Guest RedLineGTR
yep search the forums bro. it all comes down to how much u can spend. Use oil no higher than these ranges (no higher than)10W-XXW for the lowest rating and no higher than XXW-50W.
The Nissan guide recommends at 7.5-30w rating for the oil since its for a new motor its also hard to get some most people are running 5-40w, 5-30w -0-30w 0-40w 5-50w. Your choice. Check the thread buy the search button. You will find over 50pages of stuff to read. Also check google on oil myths good info if u have time to read it.
Hi all just thought i might add my 2 cents
I have used nearly every oil under the sun Mobil, Penrite, Shell,AGIP,Motul,Caltex.... the list goes on.
I think that the best way too check if an oil works for you is check the state of the oil when you change it...Colour, rub it between ur finger etc...
I have noticed that the racing oils like AGIP and Motul that i have used are only good for sorter periods then 5000KM, like a track day/weekend and then change it. But they do work really well for that time!!!
Till now i have noticed that Mobile 1 is the only oil that has kept its original characteristics...well closer than any of the others over the 5000KM.
So i use Mobil1 most off the time and then put in some Motul if im doing some track/skidpan time.
i use mobil 1 / motul 6100. Ive recently heard that the motul is a higher "grade" oil than the mobil stuff. I dont know exactly what that means but... Also was told the new mobil 1 super syn isnt worth the dollars.
havent done any tests, just what ive heard. But with most of us changing every 5000kms its prob not that important.
Guest RedLineGTR
mobil 1 is over priced for what it is and how it is made...advertising and everything costs money where else can it go. Motul oil refering to the 8100 model 5-40w rating is reasonably priced and preforms like a top oil for a good price...motul have another branded model which is 300v which is made specifically for race and indurance races track work/drag etc... this is a specific oil for this purpose motul 5w-40w is a good all rounder. The 8100 model is as close as u will get to the best motul oil (300V) without paying 40bucks for 2 litres(300v) motlu 8100 cost about $55 and is priced quite good for how it is designed and created compaired to the competitors..
Because Magnatec is a mineral oil and breaks down a lot easier than synthetics in turbo engines. I wouldn't touch it with a 10 foot pole. All of its virtues of "sticking" to upper engine parts are also apparent in any other good quality oil. "Magnatec" is pure marketing!
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
