  • Replies 63
Posted Images
i was dissapointed with 179rwkw. Talked to the guy later and he said that the dyno has been reading quite low.
To the guy in the monaro who thought he would win, kevin (lauz's dad) in the r32 GTR got 321kw so in ya face haha
im assuming Dan was running the dyno?
thanks for the pics Niroj! yeahh ahh well i guess it was fun cept the whole waiting thing lol.
Lol @ the mitsubishi 4WD that got dynoed and the guy raged that he only got like 70rwkw hahaha
Yea thats what he says, i call bullshit
Err.. hes one of my best mates and I have been through the entire build up process of that car.
Ask Dan at Springy who looked over the car - How is a stock toyota ECU that had speed cut at 180 (which is why it cudnt pull over 307), Yellow injectors for EVERYONE to see, standard coilpacks (no DLI or larger) an external wastegate with NO form of boost control, bullshit?
When the Sard 800cc injectors,ignition upgrade(coils) and the PowerFC go in, then itll make the sort of power the motor it was built for .
Just because ur RB25 made a laughable 170 at the wheels doesnt mean that other people talk shit. If you had half a clue, the bonnet was up most the time for anyone to see, but I suppose the most youd know about is blow off valves and boost controllers -
Edited by Starionturbo
1) larger wastegate spring
2) remapped ecu
3) high flow injectors
As for the speed cut, if you want ppl to believe that everything is standard then of course you would leave the speed cut on.
You seem to be getting very defensive, are you going to tell me that this sort of power from a standard 1j is normal, this sort of power from an untouched 2j is not normal.
Also i assuming it was 300rwkw?
Edited by W0rp3D
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
