  • Replies 49
Originally posted by Jamezilla
I went on a photoshoot to an S&M establishment a few years back - for a leathergoods website if I recall (which I do as it's not something you easily forget) and as we were packing up, noticed an interesting device in the corner...
Wow Jamezilla.. so you into S&M..... so where are the photos:shake:
Originally posted by MzDfectd
i dun even fart
haah
for 7 years the bf has been trying to encourage me to do that for him
i still to this day refuse
and always will
Ambz... you don't fart... I hate to be around the day you let one go!
Cr34tion: I'd have them on CD backup somewhere if you really want :)
Was for a leathergoods manufacturer website job - it just so happened they provided alot of specialist items above the usual handbags and belts.
I can draw you a picture of the scatbox if you like too :)
all will be revelead here young matt :rolleyes: brace yourself. ...
http://www.sexuality.org/l/sex/glorhfaq.html
disclaimer: while i may know certain such things, i have not participated in said activities :) just for the record ok? hehe
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
