I ordered the wrong part number, i needed the rears and ended up with the fronts :D
Not much more to say other then they are brand new with one box not even opened. They are 324 x 30mm slotted and fit the R33 and R34 GTRs or an other Skyline that is running Brembos
Asking $900 + Delivery
So how much cheaper then what they cost me do i have to let them go to get rid of them ? :D
If anybody is looking for an upgrade then i can also supply brackets and used F50 calipers for a pretty good upgrade for those running 17" wheels
Let mick know you have thses as i know he needs them for his race car, just depends on whether or not he wants slotted or solid , but he will deffinatly need fronts to run same brake pakage as mine .
cheers
Tim,
Roy how do you go matching the F50 pad to a 324mm rotor?
Reading an old Hyper Rev there was a brake comparison for an R32 GTR. It was std, vs R33 Brembos vs 324mm Project U rotor with F50 caliper vs 4 pot Project U 342mm rotor and 6 pot 355 Project U setup.
The F50 and 324mm Project U rotor ran about 80 deg C cooler then the std GTR Brembo setup, but still some 150 deg C hotter then the 355mm 6 pot setup...which is what you expect really.
So the F50 definitely works well with the 324mm rotor, well at least better then the OE Nissan Brembo...lol the F50 caliper, the caliper for all occassions :blink: It can be used on a 324mm rotor through to the 380mm Biot rotor ;)
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
