hi i know this has probably been asked many times but i cant seem to find anything on it. i got a vl calais with a carby v8 and 3 speed auto and its on gas. im about to buy an r32 4 door skyline with front end damage. its got a rb20det and auto transmission.
my question is how hard is it to drop the r32 engine and gear box into the vl?
wat other bits do i need?
do i need to get exhaust made up or will r32 bolt up?
much appreciated.
https://www.sau.com.au/forums/topic/254191-vl-308-to-rb20det/
wen its done i will be selling it. wanna get a house
It will probably cost you more to do it than the end sale price...
Why not just get rid of both and not wasteyour time???
Not being rude, but VLT's are pretty cheap. What makes you think a non-original 2 litre version of a VLT is going to be an attractive car???
(attractive meaning get a few bucks from its sale)
IE> If I were looking for a turbo VL, id be going for an original 3 litre version where insurance and the police wont give me a hard time about mod plates
I mean the rb20 is not the greatest motor for torque or outright power, then you put it in a heavy chassis...
Why replace the 308? They are a strong engine, parts are cheap, a few bolt ons (or if you can be bothered tearing the engine down) or a stroker kit and you can push great, usable numbers with amazing bottom end torque. This isn't to mention it has 2.5 times, or thereabouts, the capacity of an RB20.
My advice would be to look at a 308 to 328/355 stroker kit with SCAT crank and conrods. Like these http://www.pro-stroke.com.au/stroker_kits.html
or if you can't be arsed doing that go with edelbrock heads, intake manifold and a nice mild/hot (depending on your preference) crow cam.
Also convert to PULP.
Of course if there is a reason as to why you would do such a conversion other than "because" fair enough and good luck to you.
this post is common sense
put a 5 speed gearbox behind it, or do you only have an auto license? (lol)
cheers for the info guys. didnt realise the rb20 was so disliked lol, the reason i gonna go the rb20 was because the car its comin from has done under 100k and and at a good price. but yeah i might leave it as it is.
how much are rb20det and gearbox worth these days?
like 1000-1500.
go on calaisturbo and look for the rb20 thread. lists all the parts you need for the conversion, and everyone whose been nothing but let down by it. theres just no low down torque for big, relatively heavy car. most people start with an RB30, and the conclusion was your beter off to turbo that, starting from a V8, i'd do as suggested above
Correct me if I'm wrong, but don't the R32 and VL have similar weight? It would be moreso the 3.08 V8 diff, or even the 3.45 VLT diff that will let down the rev happy RB20 - IIRC most of the whinging about them on CT was due to the unhealthy fixation with drag cars on that website. You will find a ton of info there about a conversion though, just beware the amount of wankers and schoolkids that tend to congregate on there.
on the rego sticker on the vl i had ages ago it was 1200ish kg. the rego sticker on my R32 said 1300ish kg. i remember when i had both of them, comparing the two and to my supprise the 32 was heavier.
edit: and yes, a straight swap with the rb20 and they dont go that well. once i put 4.11s in my vl (rb20 conversion) it went alot better.
Edited by QWK32
rego stickers are bs for weight. my mates soarer says its 1250 lol
i dont think there would be much in it, either way, but its still got no low down torque, especially when you look at results of turboing the RB30, or mod the v8
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
