Group Buy : Motul 300v 10w40 (victoria Only)
MOTUL 300V 10w40 $89 for 4 L rrp $109 i will need about 15 people for this to go ahead no money up front will be needed
just leave your name if your 100% interested at the end of it i will get stock sent to
STATUS TUNING
63 Rodeo Drive
South Dandenong
Phone: (03) 9792 3333
Fax: (03) 9792 5555
E-Mail: [email protected]
OPEN 9.30am - 6.30pm Monday to Friday
(victoria) and can be paided and picked up from there
i will leave this up for 1 month from the 27/01/09 - 27/02/09
stock is coming from link international in Queensland
cheers
300V CHRONO
10W40
New 300V series is racing lubricant for racing cars.
MOTUL has developed “Double Ester Technology” for new 300V series, superior to complex ester that recognized the best base oil for engine oil up to now. Double Ester Technology, made by carefully balancing the ratio of complex ester and the newly developed macromolecular high polymer ester, enable base oil more wide-ranged, and delivers high output performance and superior reliability.
Also by carefully selecting the right polymer, “0% shear loss*” can be achieved.
*Diesel Injector method (CEC L-14-A-93), a standardized testing procedure for a lubricant’s shearing force.
Can be mixed with another viscosity of same series to achieve most suitable viscosity for the engine. (except for 5W-40)
* All-round use, designed for handling stable oil pressure preservation and sharp response.
* Compatible with a wide selection of engines — naturally aspirated, high torque turbo and cars that produce average to high levels of exhaust fumes.
SPECIFICATIONS
Product 300V CHRONO
Feature 100% Synthetic, Double Ester Technology, 0% Shear loss, can mix, for cars only.
SAE/DOT Standard 10W40
Specification Exceeds all existing standards
Maker's Approval —
Compatibility For a wide selection of engines — naturally aspirated, high torque turbo and cars that produce average to high levels of exhaust fumes
Why is it that motul dont make any of the 300V in 5L's? I asked the link rep last time he was up in our store and he didn't really know. Is there a reason for it? Always wondered about this.
  • 3 weeks later...
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
