  • Replies 219
Posted Images
Ricky: It starts from South Street and heads north from there finishing in Burswood. So not exactly mandurah, but it'll be good to see you there. If not I'm planning another one (it's a great way to entertain yourself when travelling down south :D) that will go halfway to Mandurah before heading north again. I'll be holding that in a few months if you want to come along.
Sunny: mate you better be there!! I need my tools back ;) But seriously it'd be good to see you there.
Lachlan: My first cruise was a large one like this, and as you can see I haven't given them up yet! Come say hi, I'm driving [NA 33 WA], I don't bite :banana:
Nick: Thats no excuse mate. Steal the V8 Jeep off the wife or bring the Tonner. Not sure if it's running though. I did say open ;-)
ahaha cant wait 4 this cruise the night b4 im going 2 my mates PGA cruise (pulsar group australia) i dont think theey want my 34 there so i will b in a pulsar Q ftmfw ahaha... but should be good to see how this one compares lolololol
clutch is getting worse and worse!! So trying not to drive it atm.
and the clutch wont b arriving to my house till end of the week...
May need to ride shot gun with someone.....
Good to see you there Simon, saw your car at the Plex a few weeks ago so it'll be good to see it up close and meet the driver.
Teo, I'll send you the map on MSN, don't really want to put the map up on the Internet for obvious reasons.
sure thing just send me an offline msg or if you can email it to me so i can plan the journey in case i get lost : )
After working that orning making the drifts will be a bit touch and go but I am now definitely in for the cruise.
In saying that I'm not sure whether I will meet up at Citywest or the South Street park n ride. My only problem being I don't know where South Street park n ride is and my sense of direction is so poor that I couldn't navigate my way out of a hole. Can anybody help me out, where exactly is the park n ride?
haha I dont know where it is too, so just hope some people meet up at citywest and I'll just follow them..just rock up to citywest with us
Edited by viet_boi
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
