ok i love my music and love bass but i have been looking into the weight problem as of lately.
atm i have 2X12" clarion subs which packs and a fair decent punch but it weighs a billion tons lol so i am after a single sub that can pack somewhere close to 2 subs. i have a 1000wrms clarion amp so planning on running the new sub of that.
so suggest away a sub that may suit me. budget wise ill be looking at spending upto $500
this is my boot atm lol
so ye if anyone can recommend a decent sub nothing high end as i wont be entering this in any comps just want to reduce the weight and get some boot space back that will be great
ta
Ash
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/
One sub acting like two?
You need a DVC, Dual Voice Coil.
In my opinion, $500 is a great budget for a DVC sub.
My recommendation would be ...
Rockford Fosgate Punch Series P2L-112
http://www.caraudiowarehouse.com.au/catalo...646bcdd4d7f165c
OR
Any of these Power Series subs, enclosed in a custom made box to suit the volume needed.
Can be tuned for heavy and deep bass, or just normal listening..
MRXTCZ
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4392451
I never got it but i am still inlove with the kicker solobaric L7. I chose 2 mtx 5500's instead because it was a much better price for me 4 years ago.
Pick them up with a ported box from kicker for under $500, off memory they were 650ish rms. basically the L7 is like 2 of my mtx's combined in one smaller and light weight unit. Just set your amps subsonic filter and that properly and you shouldn't have any probs running it from your 1000rms amp. Anyway it will sound very clear since the amp can easily handle the subs demands, no distorted peaks getting cut off and all that....
Still impressed by it today, and if my mtx's ever give out i'd probably get a couple of solobarics to replace
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4393207
Solobaric or Fosgate, JL audio , all rellay good for the money
and many more.
I was going to say , WHAT BOOT its all box?
mine has a recycled 12 DVC sub in a fiberglass composite box, flush mounted BEHIND the side panel near the jack.cant see it at all
removed the jack and put it on top of spare in molded holder. custom built
but more then enough room to flush mount a very serious 10-12" and keep it out of the way, I lost , no part of my boot to sub and only a slight bit to hold the 3 amps in a false floor , both sides if the car have room for subs by the way in a R34 GTT
just have to be creative, you also have plenty of room for a single relfex custom made box under the rear deck for a 10" which will outrun your clarions by at least 3 times over if done correctly. in a honda we hit 143 db with a 10" rockford in a small box described above and 800watts on it ? serious thump
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4420736
the new JL Audio slim-line sub.. the enclosure can be amazingly small but it has real punch.
http://mobile.jlaudio.com/products_subs_pa...php?page_id=245
wow that looks impressive, I went with a Peerless 12" Automotive in a fibreglass box made by loftyfang. It kicks hard enough for me and sounds nice :D
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4422723
I think if you have the money and want some serious bass, take a look at this test
you can see all the favorites fail ...lol doesnt mean there bad but if you want incredible take a look..lol
http://www.orioncaraudio.com/Promos/HCCA_C...ge_Results.aspx
Orion has made some of the best woofers around for the price for a long long time? even the lower cost ones are great and take smaller boxes then most others ???
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4437148
Not sure if your budget can afford it but I highly recommend Boston Acoustics. I believe that they designed to be mounted in a 1cft enclosure so thats gotta be a decent weight saving. Plus they can take an absolute pounding and beg for more
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4447335
Yep I can vouch for the quality of Orion. I ran 4 x 15" XTR subs back in the early 90's. They were near indestructable .
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4447350
http://www.alpine.com.au/products/product.asp?modelID=332
All your problems solved. :D
This is a dual voice coil, can either get 2 ohm or 4 ohm. 500rms. Sounds like you have two 12's in the boot with the right amp of course :O
I recommend a awesome amp. MRD-1005 Alpine which they dont stock anymore but is tops cause its a 1000rms mono block amp which means you can always add another 500rms sub into the mix, and in the meantime still run your 1xType R Alpine to potential but always be sure to set your gains correct. Cause you dont want a popped sub like we've read above lmao...
Another good amp which my friend is using and it pumps is http://www.alpine.com.au/products/product.asp?modelID=374
And prices are much cheaper at jb than alpines site.
So for under $1000 ull have nice clean,crisp bass..
Just my oppinion thou, hope it helps.
Edited by DRFT31
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4448318
Dont know how far up the range your clarion subs are but i had 2 bottom of the range 12" pioneer subs in my car when i bought it, replaced them with a single jl and it sounds better than the pioneer, better response and better clarity.
https://www.sau.com.au/forums/topic/254433-suggest-a-sub/#findComment-4452111
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
