Wonder if you can get electric cam gears, map them to load points in the tune. Now that would allow for some very good gains. Basically be an aftermarket VCT/VVTi
Only problem is you'd probably need a motec to tune it effectively.
HKS VCAM ?
Yep BWRGTR - cam gears ;)
Less than $300 even :)
Just use a NEO head, poormans HKS V-Cam :3some:
Obviously doesnt work as well, but you still get the VCT bonus.
Only issue is you need adaptor for the NEO head to get the 26 plenum and so on (and some porting)
Well it helps with the lower end, which is the ole sticking point of the RB26 in many respects and lets you get the top end also!
So for the cost it's not "too" bad if you are doing a build given you sell off your head etc.
Of course lovely v-cam would be the best option, but @ around 5k... it's not the most affordable solution
Yeah might as well just get a completely different 6 cylinder for that price that already has those sort of features built into it. Pretty sure the VQ35/37 do it.
But then God would send a great flood to punish you for your sins and yeah Nismoid is right, if you know where to look you can get HKS or OS GIKEN cam gears for 300 ish.
Edited by Nee-san
For the Turbo Guru's out there when we are referring to the -9's are they the GT2859R-707160-9 model that Garret Lists
I am trying to get pricing on a pair for a GTR
I know the -5's and -7s are the GT2860R - 707160-5 & GT2860R - 707160-7
thanks for the help.
Should I be doing turbos on my new car? its got 80,000 on the clock and I was going to take it into Trent to do power fc / cam gears timing belt service / and basic stage one mods.. would you guys recommend I get trent to do turbos at the same time? how much roughly extra would it cost and am I right in saying it would make about 80kw atw difference?
edit: sorry if i seem noob new the the rb26 game :P
250rwkw is around what you'd expect stock turbps, and then 300rwkw on a unbuilt motor which is nice and safe
overall cost would be around 4k for the lot including turbos/labour/fitting/gaskets etc.
thats not including front pipes (if you don't already have them done, thats more cost)
If you're going to put new pair of turbos, you may as well do the clutch while you're at it (unless you've got one already).
As for you putting the turbos, it all depends whether your standard turbos have sign of letting go or you're power hungry that standard turbo couldn't provide.
That said I've got GT-SS in mine and at 302rwkw it may sound fun but I want more.
Yes Ash is spot on around $4-6k is what you'd be looking at upgrading to bigger turbos.
I should really put up my dyno sheet.
Also looking to find the answer for this. Trying to buy the HKS GT-SS equivalent
Depends on who's site you use. Garrett changed labelling a while ago as well which didnt help so some sites are not updated.
Seems at times American sites have them labelled differently as well.
The GCG link is correct in AUS.
Well I'll be buying them from MTQ here in Adelaide. Guess I'll just ask for Garrett GT2560 -9 /707160 - 9 then push the point that I want the HKS GT-SS equivalants for my GT-R. Hopefully they order the right ones.
Just give em the cartridge number, always get the right one that way.
Shop around, I've found MTQ sometimes to not be the cheapest (same for GCG)
prices seem to vary as much as $100 place to place.
Getting them for about $1,200 per turbo so I doubt I'll find them cheaper.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
