Not likely mate Piggaz 2.8L stroker with all the fruit is probably at around 20psi @ 4K. Full boost on your car would be around 5-5.5K id say.
I'd hope not - my GTRS's were on full song @ 5.5krpm.
When I had -5s, the turbos were getting tickled at about 3.5krpm and pretty were in 'get up and boogy mode'.
Both examples on 2.6ltr.
Sounds about right.
That thing of Paul's is a weapon, and not the average build. It's got ALOT of rnd and tricks, all of which work. A lot of secret squirrel.
yep totally agree with you.
IMO -5s on stock 2.6 will see full boost around 4.5-5K - if you get it earlier than then I want to know.
firstly are you really running 25lb????
secondly if you are, how bout you throw a dyno chart with boost / rpm curve so we can see at what RPM your really making at full boost with -5s....then we will all know.
Edited by Ants
I'd really like to see an overlay of -9s with -5s on a dyno graph.
Does anyone have this info or happy to post their graphs running -9s and another with -5s...from here, we can overlay to see the difference...would put a lot of debate to rest
There is one out at unigroup on the same car. On the dyno, they came on exactly the same but the 5'a made more grunt. However, to drive they were a TOTALLY different car!
What's wrong with running 25 psi Ants? :P
LOL....I was wondering when you were gonna say somethin.......aside from being a ship load of boost nothin really just curious.....about how long an engine would last if predominately driven at that boost level :glare:
Edited by Ants
That is odd Paul. Dyno shows that they huy full boost at same rpm?
Didn't answer the question.. why the doubt? I am offended.
Ill try and get the sheet. Or it could have been the power low end was the same but boost levels were pushed to the right a tad on the 5's.
Leave it with me.
I spose the tune would have a massive part in this. Mine lasted 7 years with anything upto 2.0 bar shoved down it... Only died because the oil pump had a hissy fit.
Mate I watched a built 26 with -5's and poncams on a dyno for a good hour and full boost was by 5000 and it went to 345kw iirc. No chance of getting -5's in by 4 on a 2.6L ;)
  • Like 1
I know Paul.....I know. I'm just conservative and want to have an engine tuned to last as well (I will certainly not push my advance spec beyond 25psi). Your car is insane and would of loved to have a 2.8ltr with similar mods to yours :)
Keen to see those graphs though.
Edited by Ants
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
