Piggaz Posted April 11, 2013 Share Posted April 11, 2013 GCG are wrong. -9's are bigger. Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6812558 Share on other sites More sharing options...
wedge_r34gtr Posted April 11, 2013 Share Posted April 11, 2013 GCG are wrong. -9's are bigger. Yep, Paul is correct Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6812583 Share on other sites More sharing options...
hazjaz Posted April 11, 2013 Share Posted April 11, 2013 (edited) Wow, this got confusing. So I searched garrett official website to get the measurements of a GT2860-9 and it turns out the GT2860-7 that GCG apparently have are the same measurements as listed GT2860-9 on the garrett website.. I don't know how that works but numbers shouldn't lie.. Right? Edit: The gcg -7 are the following: Inductor- 47.2 Exductor- 60.1 That sounds like a -9 ? Edited April 11, 2013 by hazjaz Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6812671 Share on other sites More sharing options...
hazjaz Posted April 12, 2013 Share Posted April 12, 2013 delete me! Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6814065 Share on other sites More sharing options...
hazjaz Posted April 12, 2013 Share Posted April 12, 2013 (edited) Sorry guys, it wont let me edit the above post. After a few more hours of reading through threads on this forum I have come to the realisation that the -7s are GT2860-7 (707160-7) and the -9s are GT2859R-9 (707160-9). Going off the stats on the Garrett website, the -7 is a bigger turbo? In that case why is the -9 the one with the better performance and able to push more power easier? GT2860-7 (707160-7) COMPRESSOR Ind Whl Dia(mm) - 44.60 Exd Whl Dia(mm) - 60.10 Trim - 55 A/R - 0.42 TURBO Whl Dia(mm) - 53.90 Trim - 62 A/R - 0.64 GT2859R-9 (707160-9) COMPRESSOR Ind Whl Dia(mm) - 44.50 Exd Whl Dia(mm) - 59.40 Trim - 56 A/R - 0.42 TURBO Whl Dia(mm) -53.90 Trim - 62 A/R - 0.64 If anyone can clear this up for me that would be great, based on the read I have done -9 is the ones I want, but turns out they are actually smaller.. In which case -7 would have more potential? Edited April 12, 2013 by hazjaz Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6814116 Share on other sites More sharing options...
wolverine Posted April 12, 2013 Share Posted April 12, 2013 http://www.skylinesaustralia.com/forums/topic/423175-r34-gtr-turbo-upgrade-needing-advice/#entry6811557 I know this will seem like you are going around in circles but the information has been given to you in a user friendly way. The flow potential of the -9 is higher than the -7. Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6814129 Share on other sites More sharing options...
Marko R1 Posted April 12, 2013 Share Posted April 12, 2013 This is pretty much gospel: -7s 300kw -9s 330kw -5s 360kw+ I am very surprised with the info GCG gave u... Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6814144 Share on other sites More sharing options...
Piggaz Posted April 12, 2013 Share Posted April 12, 2013 It really is this simple; After 'response' on a 2.6 = -9 (330 rwkw or so or squeeze 350 + on E85 on a 'normal' setup) *350 plus on 98 If you can put up with a lethargic result for more top end (360-380) on a 2.6 = -5's. Stroker = -5's 3.0 with a bulldog curve = -5's -10's/RS's = in the bin. *Well setup cars are the exception. Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6814145 Share on other sites More sharing options...
Marko R1 Posted April 12, 2013 Share Posted April 12, 2013 Haha bulldog curve, is this your new quote paul -10s in the bin looool Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6814147 Share on other sites More sharing options...
hazjaz Posted April 12, 2013 Share Posted April 12, 2013 (edited) Thanks for the reply guys. I will be going for the -9s. I'm sure if I quote the model number and ask for the HKS GTSS equivalent I will be getting the right ones. -7s seem a bit out of a waste of time unless you're chasing a replacement Edited April 12, 2013 by hazjaz Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6814155 Share on other sites More sharing options...
hazjaz Posted April 14, 2013 Share Posted April 14, 2013 Sorry guys, no edit button again for the above post. But after reading about the different sizes listed by garrett I went into the technical drawings and they look identical apart from the turbo outlet. Is the design of this the advantage of the -9s? Picking up the turbos tomorrow so just want to make sure 100% that I am buying the right ones. -7 http://www.turbobygarrett.com/turbobygarrett/sites/default/files/default_images/turbogroup/drawing/Garrett_GT2860R_707160_7_new.pdf -9 http://www.turbobygarrett.com/turbobygarrett/sites/default/files/default_images/turbogroup/drawing/Garrett_GT2859R_707160_9_780371_1_new.pdf Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6815635 Share on other sites More sharing options...
Piggaz Posted April 14, 2013 Share Posted April 14, 2013 -9's. Done. Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6815709 Share on other sites More sharing options...
hazjaz Posted April 14, 2013 Share Posted April 14, 2013 Is there only one -9 from garrett that is an RB direct bolt on? Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6815723 Share on other sites More sharing options...
Piggaz Posted April 14, 2013 Share Posted April 14, 2013 Is there only one -9 from garrett that is an RB direct bolt on? Yes. Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6815748 Share on other sites More sharing options...
MrStabby Posted April 16, 2013 Share Posted April 16, 2013 This is pretty much gospel: -7s 300kw -9s 330kw -5s 360kw+ More like: -7s 320kw -9s 330kw -5s 360kw+ Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6818125 Share on other sites More sharing options...
Marko R1 Posted April 16, 2013 Share Posted April 16, 2013 ^ really? I had no idea -7s are that close to -9s Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6818127 Share on other sites More sharing options...
levinboy Posted April 17, 2013 Share Posted April 17, 2013 More like: -7s 320kw -9s 350kw -5s 360kw+ Now fixed Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6818553 Share on other sites More sharing options...
(OO)SKYLINE(OO) Posted April 17, 2013 Share Posted April 17, 2013 http://www.skylinesaustralia.com/forums/topic/423175-r34-gtr-turbo-upgrade-needing-advice/#entry6811557 I know this will seem like you are going around in circles but the information has been given to you in a user friendly way. The flow potential of the -9 is higher than the -7. That's right! -7's and -9's have the same size in specs. From memory when speaking to Racepace, the reason why the -9's have better top end is due to the configuration of the turbine blades. Ones longer and the other shorter (the shorter blade allowing more air to flow through). Also to do with the pitch angle of the turbine blades. It's at a certain degree to allow more air. Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6818621 Share on other sites More sharing options...
vspecIInur Posted April 17, 2013 Share Posted April 17, 2013 Hmm maybe if I go -9's from N1's I can get my 400kw Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6818848 Share on other sites More sharing options...
Piggaz Posted April 17, 2013 Share Posted April 17, 2013 ^^ isn't worth the effort IMO. Link to comment https://www.sau.com.au/forums/topic/254450-79s-or-5s-garretts/page/25/#findComment-6818872 Share on other sites More sharing options...
