  • Replies 138
?? NISMO - Nissan Motor Sport OEM supplier, so direct fit for R34GT-T.
I'm not trying to pedal anything, just saying that that bloke made a mistake when he said that R34 NISMO injectors were 440cc that's all.
I'm not trying jam them down anyones throat, just trying to help out with some options. :)
Fair call, I'm just trying to figure out if there is a larger equivalent that came factory fitted to another engine. I can't justify near on $1k for an extra 100cc's for my daily :)
Deutschworks?
Does anyone know how big 350Z injectors are? being a 3.5L engine I'm hopinh they're bigger than 370cc..
From memory they're about 300cc....not big at all, as some zed people are using the R34 Blue 370's as upgrades.
I've been more than happy with the deatschwerks injectors, I've got the obsolete 550's the newer 600's replaced them on their site last year, they're 100% drop-ins
I remember asking the question about the XR6T injectors a while back, never actually found out though :)
480cc'S can go more then 242 kws cant they
from memory i pulled 215 from stocko ones would 100cc really be only 30kws more
(oh mines currently at 244Kws (have run 248Kws) with nismos and I could have sworn they were not maxing out yet )
Well my stag is making nearly 240awkw on stockers, they were pretty much maxed at ~260awkw and there was still a few psi left in the turbo which is why I'm looking for something a little bit larger :)
Edited by bubba
ok, blitz made good ones but discontinued, so pretty much forget about those. One wrecker i think in SA has some second hand ones but for about $1200
Nismo are the ONLY drop in ones, 4 hole spray pattern, $1200-$1300 delivered, stupidly expensive and rare as hens teeth to find second hand, trust me, i was looking for a while until a set turned up on ebay. And what do you know, someone on SAU is selling a set :banana:
Sard aren't straight drop in like the Nismo's, and frankly, don't have that brilliant a rep compared to the Nismo's.
Other options then become...
GTR injectors (need fuel rail and possibly resistor packs)
HKS fuel rail which gives you more options
Hi flows - done here locally or done via deutchworks, some people love them, some people hate them. RC Engineering in the states could probably also rustle up some hi-flows.
Then, i was going to go with ANOTHER option until i found the Nismo's. A guy in Melbourne was advertising converting side feed to top feed, using these billet aluminium bungs or something. I asked if he could go the OTHER way, top feed to side feed. Because if us NEO'ers went to side feed we'd have a ZILLION options. He doesn't see why you couldn't go top to side, but i never followed through with it cos i found the Nismo's.
I know there's no OEM info, but that's pretty much what i found out with after market options for the NEO, and yes it's VERY limited if you don't want hi-flows or get fiddly with new fuel rails.
I reckon someone should give the top-side feed conversion a shot, cos surely then there would be a lot more options available.
I had actually toyed with the idea of putting the R33 inlet runners on the Neo head and just using R33 side feeds on the stock rail....but I never got around to confirming the stud patterns matched up, anyone care to check it out?
Yeah thats the one, i got them ones highflowed to 555cc.
You had 350Z injectors hiflowed?
Also, anyone know if a 26 fuel rail will bolt up to the intake manifold? or could be made to bolt up? a fuel rail is just a fuel rail afterall.. and being able to use GTR injectors means I could then also use hand-me-downs from my 30!
Edited by bubba
  • 3 weeks later...
Hey ppl's I'm still working on this little project. just waiting on a bit of cashola to come through.
can any 1 confirm if Neo Rb25 heads have the same injector spacing and mounting positions as a non NEO RB25 head?
also do R33's run the same style stock FPR. as i want to retain the stock FPR?
regards
Chris
you are a dingis . have you not read anything about this sublect at all ?
You sir are a Dingis for using the word Dingis. LOL
I am very confused at why u think this is such a stupid non thought out project.
Was it the part where I'm going to use cheap common injectors or the part were i asked if Neo and non Neo's had the same spacing between injectors.
Whether they be top feed or side feed is irrelevant.
Please explain where I have gone very very wrong?
regards
Chris
Edited by urtwhistle
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
