Shame the weekend finished this way for us- we were running 8th outright at the end of the first day - not bad for Pete's first steer in the car.
Sadly, it looks like just a case of crap road surface (gravel, melted tar and oil don't mix) coming out of the corner, putting an end to an otherwise good run.
I think Pete's driving is the only reason we didn't roll- he managed to wipe some of the speed off and hold the car balanced as we slid 12ft down the bank!
Actually Liz, alot of the farmers who raced up to see the damage thought i had been driving - I ofcourse told them I would have caught it if that were the case >_<
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4403607
went out and saw the car today. not a massive amount of damage just the just the coolers radiator etc were pretty messed up and also a heaps of the guards. transplanted what needed to be transplanted from the half cut (also there) and it should be good. other than that all the 4 wheels were bent and some other little under car stuff i think
pete said the main amount of damage to the coolers etc happend at the bottom when it hit the ditch..also said he was very lucky that he didn't hit any trees and what not.
and also said kel was very very calm and seemed to care more about pete than the car :laugh:
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4413447
My middle name is calm :(
Pete did a great job to slow the car down and then keep it together as we headed down the bank- i keep saying this but i still have no idea how we didn't roll.
He's a bloody good driver, and it's such a shame this happened because he was on track for a pretty good result for his first time in the car.
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4413475
  • 3 weeks later...
There really wasn't that much damage to see - the front bar was barely marked, just hanging a bit loose. There was some panel damage to the front quarter panel from memory from hitting something solid on the slide down the bank, but again nothing too look at.
By all accounts Pete has almost got the car back to brand new and definitely ready for Targa in a few weeks.
https://www.sau.com.au/forums/topic/255087-oops/#findComment-4443132
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
