i think mine is 5 hole? ill have to double check.
if all goes well im going to buy a R33 GTST ABS diff with half shafts tomorrow.
also one more thing, will the R33 diff bolt to the R34 GT25 NA tailshaft?
yeh my NA R34 is open centre, 1 wheel spins only :P
  • Replies 49
Posted Images
yeh my NA R34 is open centre, 1 wheel spins only :ninja:
Let me know how it all goes once you get it done man, or do a write up, im getting tempted to weld my centre :P
^ don't weld it mate, makes daily driving a big fken nuisance (sp??) i had a locked diff in my old silvia, it was fun but very very annoying!
lockers have never really bothered me to drive with, probly a personal preferance, but i have resisted the urge to lock it n id rather sort out an lsd, so let me know how yours goes
good news, fits 100%!!!!!!!!!!!!!!!!!!!
for all you 25GT guys out there, rush out and buy a R33 GTST ABS DIFF, Auto preferbly (as its got teh same ratio, 4.363) otherwise a manual 4.11 will just be fine as long as its got ABS.
:D:) can do sick skids now!
f**king Excellent! My GT will do 2's with a bit of brake feather, but goes back to single as soon as you get more than like 30 degrees of angle, i know whats next on my shopping list :D
EDIT: do the stock driveshafts bolt up?
Edited by Silver_GT
yes, stock driveshafts bolt straight up, as long as you get a 5 hole type.
ive read up that the GTST ones are stronger then the 25GT but in a NA, it doesn't really matter as its not packing much power & wont know till it breaks and i replace it with a GTST item.
Yeah thats what i thought dan, pretty much the whole suspension in a 25GT is pretty much identical a R33 GTST.
great stuff, most of the r33 and r34 stuff is interchangable. When you say that you use the stock driveshafts, do you mean that you used the stock gtst 5 bolt rear shafts? Its just every r33 na diff runs the 3x2 bolt rear shafts, the same as my r34 diff atm.
If anyone else wants to do the conversion, best to use the stock gtst manual diff, the auto diff has a ratio close to 3.5:1 which isnt very nice for a low torque engine like the rb25de
I'll be putting the r32 gtr mechanical diff in my r34 in the next few months, i'll let you guys know how it goes.
Congrates, now for some skids :)
i used the stock R34 drive shafts (mine had 5 hole type not 3x2 hole). i thought the auto diff was a higher ratio, like 4.363? (thats what my search uncovered and manual is 4.11) I know R32 GTST run 3x2hole half/drive shafts
really 5bolt shafts? my r34 diff is the crap 3x2, must have something to do with the gtfour model.
4.3ish:1 ratio is the manual gts4, 4.11 is the gtr. Autos are definately much much taller gears, around the 3.5:1
Theres a bloke i use to know that had a auto diff in his r33 (was converted to manual) and the gears on that was redicously long, as in you wouldnt bother going back to 2nd at 50km/hr to give it some shit, you go back to 1st :/
Definately wont go well with a na skiz, way way too slow
My diff has a 3x2 shaft setup and its just a normal 2wd 25gt.I am now actually confused as to what diff I actually have, All i know is 2way diff ftw :D ...
All I want now is a set of 4.3 gears to make my car accelerate a little bit quicker...
Does anyone have some for sale here in brisbane?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
