well im out.............. i just blew second gear tonight in mine
i suppose ill come and watch and i still want my calendar
any idea's on new gear box for r32 2.0lt ? 32gtr box any good?
  • Replies 140
Is there a price for lowest reading kw car?
Yeah... I'm willing to pay $500. (hint: note your spelling)
Bummer :blush:
RB25 gearbox mate :blush:
rb25 box are supposed to be good but ive been told that the gtr box is way better and pretty much un breakable?
any oppinions?
need one asap
anyway ill be there today still maybe chat to you blokes there and the mechanic running the show ay
The rb25 boxes are just as strong as the GTR boxes. Whoever told you the GTR boxes are unbreakable is incorrect, just as Jack who has busted 3 or Chris who as done 1, and a few other people. Yes they are one of the strongest factory boxes ever produced but they can break.
Just got home. Was a good turnout, and some really nice cars showed up.
Great to meet people face-to-face. Nabbed a few photos. If anyone has any objection to their car being posted up, PM me.
Thanks.
THANKS A CRAP LOAD AJ 'CAJFLY' for ringing i completely forgot haha. was pretty big when i turned up. wooo membership expires Decemeber 2010!! LOL. ohh and took some pictures whilst the car parks were full i'll upload them shortly!!
Bah - the attachment system freezes whenever I try to upload more than a few photos.
Here it is on photobucket:
http://s384.photobucket.com/albums/oo281/m...20-%20Kamikaze/
There are 32 pics of around 200kb each to aid loading. Some didn't turn out all too well - unfortunately neither my camera nor I are pro :P
Edited by Phatboy
Any thoughts on the accuracy of the dyno today?
I had a confusing result at 215 4wkw compared to my last dyno session of 282 4wkw.... and today i was running slightly more boost. i know all dyno's are different but with a difference that big, something is going on with my car or the dyno. I'm hoping its not my car that's the problem.
I reckon dyno for sure bud dont stress bout your car
i watched a few runs and im kinda glad my car wasnt put up there cause i would have been disappointed also
my mechanic told me before today that there dyno was screwed it puts out weird readings apparently
reason i say this is because i saw cars on there where the revs were going up and you can hear the power coming on
hard from the turbo chargers coming on boost and yet the dyno power reading at this stage was getting lower????
ive never seen a dyno do that before. on more than one car i must add.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
