Welcome to the forums
Deca - http://www.skylinesaustralia.com/forums/Mi...ot-t255432.html
SAU Vic Renewal/sign up dyno day - http://www.skylinesaustralia.com/forums/Sa...no-t255356.html
If you sign up before the 8th, you could come on what is going to be an awesome members only cruise :D
There's a link to the online signup form in my signature below ;)
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406827
If you sign up before the 8th, you could come on what is going to be an awesome members only cruise ;)
There's a link to the online signup form in my signature below :)
Thanks Dezz
what time is the cruise on the 8th, as I got work and don't know if i will be able to make it.
also if i come to the sign up day with a filled out CAMS License form, will that be processed in time for the 1st DECA
Cheers :D
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406911
Thanks Dezz
Cheers :D
The cruise on the 8th is a members only cruise, so can't really give away any details...it begins in the morning and will run all day though..
As for DECA/CAMS, you can hand in your completed CAMS form along with the correct money on the day at DECA, and you'll be fine to compete. However you'll need to be a member of the club (or another CAMS affiliated club) to obtain a CAMS license. Otherwise you can get the AASA license instead.
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406951
Thanks everyone
I guess I won't be able to make it to the cruise on 8th anyway as i work from morning to after midday, so I'll try and attend the sign up day on the 21st and sign up there, hopefully it will still be running at 3pm as i finish work just after 2pm.
Might try to get out early to make sure I make it. :)
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4407098
Thanks everyone
Welcome mate..
Hope to see you at the Dyno day..
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4409310
Thanks for the welcomes everyone, I will hopefully see you all down at the dyno day
Hey man welcome
nice car!.. you wouldn't happen to have been parked all day on stanley st in west melbourne today?
Nah that wasn't me, I saw what looked to be an identical 180sx to mine in tha dandenongs though
Welcome aboard.
im planing on being at the dyno day myself, hopefully will see you there...
nice car by the way, i very nearly bought a 180sx myself once. ;)
Hopefuly see you at the dyno day.
What stopped you from getting the 180?
Can we Originise your 180SX?
:happy:
I would love to Originise my car, but right now I am a little short on money as most of what i saved went towards buying the car itself
How much is this kit anyway?
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4410103
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
