Got a Nismo G-Max twin platted clutch for sale (originally I thought this was a coppermix, it's not, it's a G-MAX one).
It does need rebuilding and this can be done through NPC if requested for me to have it rebuilt for you.
It's come out of a R33 GTR Skyline.
This is a pull type clutch and will fit into any R33 & R34 GT-R Skyline or can have it built to a R34 GTT Skyline.
Asking $1500 for this which includes the rebuild.
or $700 as it is not rebuilt.
Postage to anywhere in Australia is about $50.
The rebuild will be built to handle anywhere up to 1000HP.
These clutches come stock with the ability to handle around 700-750HP.
Want to sell this as soon as possible. It's located here in Brisbane.
Interested?? PM ME!!!!
Edited by JJay
https://www.sau.com.au/forums/topic/255559-fs-nismo-g-max-twin-platted-clutch/
My offer of $1000 is still on the table as thats what you quoted me
I accepted that when I thought it was a nismo coppermix one which is what I got told it was from the previous owner.
After taking it to NPC, they told me it was actually a G-MAX one, far better then the coppermix one itself.
No way am I paying near $900 for the rebuild and only making $100 from the clutch when it's worth more then that.
so this is the same clutch you were selling for $1000. for a min there i thought you were selling 2.
No, not the same one.
Originally I thought it was a coppermix clutch as that what was told to me by the guy who sold me the car with the clutch.
Since taking it out and having it looked at, it's actually a NISMO G-MAX clutch, not a coppermix clutch.
The G-MAX clutch is far better then the coppermix clutch and it does cost more.
NPC told me that these are valued at around $3000-$3200 brand new.
Also been told stock, they hold anywhere between 700-750hp.
So asking $1500 for it rebuilt (it's costing nearly $900 to have it rebuilt by NPC) isn't much considering your practically getting a brand new nismo g-max clutch!
I've actually asked for the coppermix clutch thread's to be deleted since I do not have a coppermix clutch to sell.
Edited by JJay
bloody hell u guys...it is what it is...a good price for a good clutch, if you dont like it then stop complinaing and dont buy it.
bump for a good price and a good lutch.
I'd like to know where you got the idea that a G-Max is far better than a Super Coppermix clutch.
based on the information i've been given by both a mechanic and NPC themselves.
And also whey the rebuild price doubled...... i don't understand how the rebuild price can be that different
Go ring NPC and ask for the price on the rebuild of the nismo g-max clutch and then come back to me.
the price i'm getting for the rebuild is at trade price, you ring up and they'll charge you through the roof (probably near or just over a grand for the rebuild).
Just because your pissed that I changed the price on the clutch doesn't mean you can come in here and start causing shit. If I knew it was a G-MAX clutch in the first place, then I would of advertised it as that. But since the person who sold it to me miss-informed me of what clutch was actually in there, it was initally advertised as the coppermix one.
No way will I sell the clutch for $1000 including the rebuild. That just means I'm paying near $900 for the rebuild and only making $100 from it. Seriously think about what your offering there.
Dude, still waiting for my refund for the fuel pump i didn't receive. What's going on??
Still have this for sale and I want it gone.
Make me a reasonable offer to consider.
This clutch is great for upgrades with R33 & R34 GTR's & R34 GTT's.
is this push or pull clutch
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
