  • Replies 80
  • 5 weeks later...
Check on here: http://forum.r31skylineclub.com/index.php?topic=123760.0
I don't know if it is going ahead, but it's rather close now.......... Easter is next week.
It will not suit everyone, a date and time just needs to be set and go from there. If they turn up, they turn up! if they don't, they don't.
Edited by StinkyPoo
Yes its still a go'er.
Going out on Saturday and Sunday to look at the best spots and the will post the results, times etc on Sunday night.
Waiting to get the "Long Range" weather report as well to finalize time's.
Again have the 4 days to choose from but will take into concideration of the days you wont be available.
Will keep you posted.
Alan.....
;):D:)
As promised details as listed:
Easter Sunday
Time: 9am (Nice and early so to miss the crowds)
Where: Old Dept of Taxation Car Park
From there we go down to the fountains below Old Parliment House.
There is plenty of room for you to take individual or group shots of cars.
From there to the Car Park at the bottom of ANZAC Drive.
You have the lake in the background.
Then up to the top of MT Ainslie.
For those that wish to, then a cruise to a nominated BBQ area for lunch or what ever.
If your still interested please let me know via this thread.
:wacko:
Had very little interest so far but I will be there tomorrow.
Want to get some of the GTS anyway so if anyone else shows shows up all and good.
9 AM tomorrow.
See you if you show up.
Alan
The photo shoot is tomorrow KAT .. ya haven't missed it just yet
But here is a pic I took of my skyline a little while ago near old parliament house
Just resized it so I could post it up quickly ..
my car looks a bit different now ...
Fully blacked out window tint and no rear wing now
Ahhh I thought it changed to Saturday cause of the rain that was forecast! :banana:
That looks really good btw. I'd love to get my baby up there between the trees it's a nice spot.
Edited by GTRKat
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
