hai guyz
i was out at the creeck just before, near hutchinsons reserve in lalor
and i saw foxes! a family of them!
are there many around lalor?
anyone caught them before?
we chased 1 of them, cornered it but it got away
great workout!
i just never knew they lived so close
https://www.sau.com.au/forums/topic/255592-foxes-in-the-burbs/
  • Replies 40
lol yes foxes are known to attack...i kno because ive been fox hunting before and they get nasty if cornered try to bite my cousin jumped at him, which is why im not sure why u would do that...but they are cunning lil bastards...always see em up where i live on the peninsula..lol in lalor, epping, thomastown.. i just see kangaroos everywhere...
my dad still hunts them now and again, he used to use a rabbit whistle and go spotlighting as well to get them. they had a bounty on them a while ago, i think you had to hand in there scalps because previously it was there tails but people used to cut them off and let them go so they changed it. i have seen them near some houses in sunbury at night but sunbury is sorrounded by paddocks and bush anyway.
edit: also it makes sense that they are moving in closer to where we live because they are running out of food and water. a few years back my grandma had one in her back yard she said she nearly had a heart attack and the nearest bush form her place was about 20 mins away.
my dad still hunts them now and again, he used to use a rabbit whistle and go spotlighting as well to get them. they had a bounty on them a while ago, i think you had to hand in there scalps because previously it was there tails but people used to cut them off and let them go so they changed it. i have seen them near some houses in sunbury at night but sunbury is sorrounded by paddocks and bush anyway so it makes sense.
lol we had a recording of a injured rabbit we brought from a gun shop we chucked it in a bush played it on a portable cd player on batteries and they came form all angels lol
lol thats a great way as well. set it up with larger speakers and you could get even more coming from miles away lol. :laugh:
LOL i still wana catch one of the pups
how cool would it be to have a friggin fox.
they are cute. my grandpa has a picture of one and it had the bluest eyes i have ever seen which was very strange for a fox.
i always wanted that one as a pet lol.
i see the maingy muts everyday at work (clayton) try to run them down if they cross the haul road.
back in the day the blokes use to bring there rifles into work and just shoot them, but now all the guns laws have changed, so we have to improvise :laugh:
flamethrowers instead? :rofl:
Cool idea.
lol thats a great way as well. set it up with larger speakers and you could get even more coming from miles away lol. :)
Lol..
hai guyz
great workout!
LOL!
make sure it didn't come bite ya back in the ass.
Maybe tell RSPCA or something, unless they live there and its their home...
LOL!
dude their an introduced pest. RSPCA dont give a rats arse about them
their good eating tho :happy:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
