OK, my car is an R34 GT and the centre console arragement is completely different to what I want it to be - check the pic below.
Where the CD player is, some people have the A/C controls in their R34, in that place instead. I want to see if anyone knows where I could get that version of the controls from for a good price, because I want to get a Double-Din Headunit for my car because the stock CD player has stopped working again and I am over it!
https://www.sau.com.au/forums/topic/255839-wanting-to-get-the-gtt-ac-controls/
lve got the same pop up screen in my car and am currently changing it all over to the normal a/c controls and triple gauge.
they dont just swap over as they are different widths.I ordered a new climate control trim cover for the normal type as it appears to use the same module behind from the nissan dealer l work at. lm going to test it tomorrow and l will let you know as it only cost $60 so it looks like a cheaper option.
I will let you know and if it fits l will tel you the part number.
the ac module should be the same ..but the AC fascia is definately different. However the factory radio fascia has a weird angle so you cant just take it out and pop in a 2din stereo. You need to get the double din fascia as well AND also the 2 brackets that hold the entire centre console in there ... I've just been through this conversion, trust me you will need 1) AC fascia, 2) double din stereo fascia 3) the 2 brackets that hold the ac and stereo and the fascias in the centre...
+1 on what on ducki said, and thanks for the heads up in what involved. I really want a better stereo system in my car, and if that means pissing off the screen on the dash and maybe even investing in the triple gauge cluster - for a possible turbo conversion later down the track - then I would like to know the info on what it costs and what I need to get as much as I can.
yeah sure thing, lm doing the same conversion. l will post part numbers and prices on mon night.
I have the a/c fascia part number 25570-AA002 (series 2 trim) cost appox $60-$70
the brackets l wouldnt recommend getting from nissan as they are over $100 each, lm currently trying to get them elsewhere.(but l will get exact price)
l will get the part numbers and prices for the double din trim in both series 1(black) and 2(silver) and gearshift surround if you wanna update to series 2(silver trims).
also the triple guage trim if you want to get rid of screen.
if there is anything else let me know.
I've already ripped out my LCD and replaced it with triple gauges.. Now just need the console section to make it look right since I got the sat nav panel still sitting there doing nothing. Can't remove it cause it'll leave a gap.
i recently did this conversion myself and to do it properly you will need the followng
a/c unit
surround for headunit/din pocket
you will need to replace the metal brackets that go behind
i got the above items out of a r34 gtr, same as gtt. cost me $150 from a wrecker
Edited by R-SPEC
Good ol' trade job... lol >_<
I've seen a couple of shots of the triple gauges in the thread where poeple have repainted the centre console plastics, and I am definitly wanting the gauges in mine! Even if mine isn't turbo (yet), I still want to see what my engine's doing. When I get them I am painting my console and window controls in silver, as I've seen someone do theirs in silver and it looks awesome...Silver accents the shapes and lines so well and you could get away with murder on it.
Edited by tmg
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
