The turbo is not a T3 it is a T28
The difference between series 1 and 2 turbos is series 2 have a plastic wheel, and series 1 have a ceramic wheel (i thing thats the exhaust wheel).
The standard cooler are CRAP
Daniel
https://www.sau.com.au/forums/topic/2561-r33-turbo-size/#findComment-46635
DOCTOR is correct.
The skyline turbo's (SKYLINE GTST anyway.. not the GTR) is a T3.
As for the wheels inside the turbo.
R32 GTST = T3, Steel blades on inlet, Ceramic blades on exhaust
R33 GTST series 1 = T3, Steel blades on inlet, Ceramic blades on exhaust.
R33 GTST series 2 = T3, Plastic blades on inlet, Ceramic blades on exhaust.
GTR's use 2 T28's.. don't know about the specs of the blades of the turbo.
Even though the R32 and R33 uses a T3 turbo housing the specs of the blades and the AR is different. You can usually make more power out of the T3 from the R33 engines..
Also, a lot of people don't like the idea of having a plastic wheel on the inlet side of the turbo as it is on the series 2 R33's.
The intercooler on the R33 is pretty useless if you start modifying.
I would say that once you do exhaust and filter on the R33's (or R32's for that matter), the intercooler is going to be on it's limit. And in Summer you are going to suffer a bit.
Did I miss anything?
https://www.sau.com.au/forums/topic/2561-r33-turbo-size/#findComment-46677
Guest Impul 25T
GTR's use T25's, except for the 34, the 400R and N1's.
Are you sure the turbo's are T3's? Wouldn't make for much of an upgrade putting a T3 on then would it? And I know of 25t's that have done this.
Also, the spec2 turbo is stronger by virtue of the compressor being bonded to the shaft, not fitted.
https://www.sau.com.au/forums/topic/2561-r33-turbo-size/#findComment-46795
There are different versions of T3's
Take the T3 from a VL turbo commodore for instance.. It can support more power than the T3 stuck to the RB20DET.
Or the T3 from the Ford Sierra's...
T3 only refers to the turbo housing.. it could have different blades on the inlet and exhaust side to produce more power.
So getting a T3 from a different car and having it on the RB25DET COULD be worth while.
Like alot of people do the upgrade of getting the T3 off the nissan VG30DET (old 300zx with the single turbo) and puting it on the RB20DET cause THAT T3 flows much better than the T3 on the Stock RB20DET.
https://www.sau.com.au/forums/topic/2561-r33-turbo-size/#findComment-47251
Guest Impul 25T
Originally posted by Doctor
Thats why people always go the T3/4 or the TO4.
If they werent T3 they would be an upgrade for a silvia etc but they are totally different and dont fit.
Doc
That could have something to do with the flange patterns being different.
Do you mean that the only turbo's that RB25 and RB20's can have, has to have a T3 exhaust?
https://www.sau.com.au/forums/topic/2561-r33-turbo-size/#findComment-48880
Not at all, I've got a larger turbo than that... If you do decide to go larger, you just have to look at fabricating a new exhaust manifold, or have an adapter plate made so that you can fit the new manifold flange.
You'll also find that the dump and intake sides are both different too, so new piping will probably need to be made up on either side.
matt
https://www.sau.com.au/forums/topic/2561-r33-turbo-size/#findComment-48888
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
