Hey all, im looking to do over my whole front end of my 33, wanting to put the series 2 bumper bar on you kno with the foggies and indiactors in them, also i have i beleive the series 1 grill..with the logo stuck onto it....now what i want to get is the grille that the later edition 33's have you know the one where the badge goes onto the actual bonnet and the gril is sort of open...like the r34's?
Doe anyone know where i can get these and what they would set me back.
ive seen heaps of 33's with this done, if you dont get what i mean tell me and ill put a picture up
thanks all
https://www.sau.com.au/forums/topic/256218-r33-grille/
the series 2 grill will not fit on a series one. it does not fit the lights.
does that mean the the series 2 front bumper wont fit on?
im not sure which model i have....i kno the series 1 has the smaller spoiler the more round one, ive got the taller GTR looking one but doesnt stick out the gtr one, and my "SKYLINE" logo is the same colour as my body colour not the clear one which the series 1 has, but i only have a driver side air bag not a passenger one that it states the series 2 has
its a 95
https://www.sau.com.au/forums/topic/256218-r33-grille/#findComment-4420858
sounds like s1.5 and in that case fairly sure there is cutting involved for the bumper/grill to fit the diffrent shaped headlights cant remeber exactly what the diffrence is but yeah. thats why after market companies have front bars for s1 and s2.
good luck mate, has been done so dont let a bit of cutting stop you.
https://www.sau.com.au/forums/topic/256218-r33-grille/#findComment-4423300
thanks bro, not too dissapointed if grille doesnt go on but the bumper for sure...dont really wana do the work myself might just take it to an panel beater but then they gotta know...damn why did i get a s1.5 grrrr made it difficult
https://www.sau.com.au/forums/topic/256218-r33-grille/#findComment-4423316
no probs mate, fairenough if its your pride and joy and you dont wanna accidently stuff up then yeah work shop could do it easy.
they will b able to find out what they gotta cut just by doing a quick test fit, i think its been put on the forums what you actually gotta cut but i just cant find it at the moment.
good luck mate, post pics when you get it done, the s1.5 is my preffrence any way bro they look sweet.
Gezza
https://www.sau.com.au/forums/topic/256218-r33-grille/#findComment-4424535
Gezza
thanks dude...will do wen it gets done..gotta save for the bumper first there expensive
https://www.sau.com.au/forums/topic/256218-r33-grille/#findComment-4424963
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
