  • Replies 40
  • 3 months later...
  • 6 months later...
  • 2 months later...
Thought I'd bump this topic in the hope that others may join in. I stopped for a while as I couldn't use it with my ATI/AMD HD6850 GPU after I upgraded. I have recently downloaded the Beta V7 and I can now make use of the GPU again. As far as I can tell this Beta is basically just a new way to change all of the setting in a windows based style, instead of via command line tweaks.
I got the V7 Beta from here (NOTE: there is only a 32bit version as 64bit doesn't speed up folding).
This link was a good help to get it up and running.
If you want to use GPU only then I think you can choose this when installing it.. if not it's no drama. You can change to the EXPERT screen, click on configure, then the slots tab. I ended up removing the cpu slot. Then click on the GPU slot and click Edit. To make use of the HD6850 I made the index values -1. Then go to the bottom of this configure folding slot screen to the Extra Slot Options and click ADD below it and put in the following values..
VALUE: advanced
That was basically it and I could fold after that.
There are currently only 2 Projects available for the ATI cards so the number won't really change much at the moment. The Nvidia cards really do have a major edge when it comes to folding as far as I can see.
Good Luck!
Edited by Fry_33
Yeah, I noticed it was a sticky a bit after I mentioned it :) I think it may bump it within the stickies but not 100% sure on that.
Anyway I figured it was worth getting a newer post in the thread anyway in case it could possibly get more people doing it.
  • 8 months later...
  • 3 months later...
  • 6 months later...
  • 2 months later...
  • 1 year later...
I have begun folding again and changed my team to team SAU. It has changed a lot since I first did it, I only use the GPU as the CPU just doesn't cut it in comparison. It seems you get rewarded for the speed in which you complete folds, if I complete the fold in one session (6 hours for instance) I get about 90,000 points. If I turn the PC off and resume 18 hours later with the fold part way in I might only receive 30,000 points. My points per day is over 300,000 but I haven't had it running 24 hours straight.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
