  • Replies 42
Posted Images
sau cruise with neiil=fail nissansilvia.com with cops also fail, but by the way neil sounds ns.com cruise will do me
bleh i'd rather roll with sapol than ns.com
bunch of galahs vs a bunch of gorillas
I'd go the gorillas
-D
Unfortionatly yes, Im on very good terms with him, so hopefully no problems
Kellie was also on good terms with Neil, and look how she got flamed.
So you invited the cops to this cruise? Good luck.
The cops are only doing their job at the end of the day. NS.com are just dickheads and attract the wrong attention.
So long as I have a good time ... and nobody runs up my arse ... its all good. However, with my Stagea needing another turbo, I won't be there for this one.
It was a bugger Neil put Kellie in a difficult position and wished to check cars for non-compliance of adr's. That was my understanding of the situation anyway.
I don't believe she was ever flamed, the problem was always with the request from Neil which 'spoilt' it for Kellie.
AMY STEVENS YOU DID NOT HAVE ANY PERMISSION TO PUT THIS FORUM UP UNDER ELLE'S NAME!
YOU HAVE GIVEN OUT INCORRECT INFORMATION ABOUT THE CRUISE! CLOSE ELLE'S ACCOUNT NOW OR CHANGE THE DETAILS BEFORE THINGS GET WORSE!
ELLE HAS NOT SPOKEN ONCE IN THIS FORUM!
SO EVERYONE CAN STOP HAVING A CRY ABOUT NEIL BEING AT THE CRUISE!
ELLE DIDNT EVEN KNOW THIS WAS UP HERE TIL TODAY!!!!!!!
END OF FORUM!
Edited by Lil Miss 32
Why give your account details to someone else....
Dont see people giving out their bank details and pins
And having an SAU account shouldnt be any different
MODS should be doing something about this
IBTL no more to say
END OF FORUM!
Kahli, if there are any issues with posts, take it up with moderators.
Or better yet, get your friend to take it up with a moderator.
Caps make our eyes bleed. Thanks.
-D
If I tag along, I may only be on two wheels :P The Stagea will be off the road for a bit as the turbo is dying.
i suggest everyone cans the bullshit, your either gonna go or your not, personal feelings about the way Elle has organised the cruise don't have to be aired here.
They're not personal feelings ... I'm over it. We ran a cruise under the exact same circumstances as what was being advertised here, same location etc ... only we did not put out the invite to the police to attend and we didn't advertise the meet. :( We never felt the need to as the people on our cruises were always well behaved. The odd few were reported to police, as needs.
That whole incident occurred on my Stagea cruise. The police turned up uninvited, but we still cooperated with them. No one was defected at all and we enjoyed the day. It was a pity some attitudes and comments ruin it afterwards and neither Kellie nor myself will be running cruises now. But thats SAU, love it or hate it. :laugh:
Edited by RubyRS4
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
