Originally posted by gtr13
Not midnght purple but pretty close
Actually, that is midnight purple :D
They were teh pics I was going to post from the UK forum... There are two midnight purple r33s on there with r34 rims, and that's one of them...
Looks great, but they don't fill the guards all the way... I think one of the guys used a small spacer on the hub and it looked MUCH fatter :):D
Originally posted by butthead
The white one is mine
YOU LUCKY BASTARD!
sorry cant help, they came with the car, i've heard they go for around $2000 second hand in good cond
umm.. more like $4k for a good set..
Originally posted by Merli
Looks great, but they don't fill the guards all the way... I think one of the guys used a small spacer on the hub and it looked MUCH fatter :D :D
definately! when I had them on my car they looked sweet, but needed another 10-20mm of offset to fill the guards properly. I've even heard of r34 owners using spacers for this reason.
Merli are you sure because that colour looks exactly like my GTR Dark Grey Pearl it gets a purple metalic look under sun light its a different colour to the gun metal grey of the R32's . Here is another of the same car.
Yup, I'm positive. I remember the thread on GTROC UK where that guy posted these pics of his car.
Midnight purple looks dark grey/black out of the sun.
Here's a photo of my midnight purple gtr:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
