hey guys
when i bought my car the previous owners gave me the xenon with it. its still got wires attached to it but i have no idea how to connect it up.
can anyone help me install them please???
payment can be a nice chilled slab of what ever poison you drink
ta
Ash
https://www.sau.com.au/forums/topic/257398-help-with-xenon/
actually just did some reading. would be better to get aftermarket HID's as the ballast would have been removed from the headlight along with oter components that the car came with from fatory.
all good thread can be closed sory lol
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4430318
  • 1 month later...
holly crap i forgot about this until today when my left headlight went out.
well this is what the previous owner gave me same things for each side
the back of my headlight (passenger side)
and the light itself
now i have figured out the wires coming out of the xenon with the metal mesh thing around it will joing onto the other end thats still sitting behind the headligs atm. what is the yellow plug with wires for???
i would like to get this done hopefully this weekend so any help from those who has done it will be great. be even better if i can bring the car to you and if you can do it for me??? :D
and yes i know i have chubby figures lol
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483514
fark it cold out :D
anyway took off hes headlight but hes xenons are different to urs, maybe because its a NA
but the yellow wire plug should go into the resistor and the 2 wires should go into the back of the middle globe, there will be a rubber gromet with 2 wires there most likely.
actually shouldnt be to hard to fix, solder the globe wires and then plug in the yellow wire plug and solder the other 2 wires
edit: ill be at my missus' saturday in lalor if you want me to try and fix it
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483582
fark it cold out :D
NA's didn't have xenons
unless its a gt-v maybe?
what do the parkers look like?
a circle, or a square?
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483587
fark it cold out :D
ye i figured out where the other wires go apart from the yellow on.
no you say should be plugged at the back of the light.
this is the back of the light here
i dont see no plugs where it will plug into
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483593
im thinking the yellow plug could be connectors for the headlight adjustment from inside the car.
prob be easy to pull the headlight out and see if anything else is tucked in there.
thanks anyways nick. it is pretty cold outside lol
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483602
r34 xenons dont have washers, so they are illegal
ok fair enough. i wondered why they were removed.
thanks for the info.
im not in any hurry removing mine though :D .
sorry for jumping in your thread like that ashneel.
https://www.sau.com.au/forums/topic/257398-help-with-xenon/#findComment-4483604
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
