  • Replies 354
special congrats go to Cara for organizing, and collecting a trophy which was a huge achievement based upon the large amount of cars in the show today.
Ruby for storming up to the mike when no one was looking.. to enlighten a few thousand people about SAU, oops forgot the R31
Sunscreen,, on a sunny day
and for everone who showed up to make this one of the bigger dispays
and for SAU to get a runner up club presentation,, over all the clubs, hords of domestic cars.
nice to day to chat to all. ready for the next show..lol
thanks to everyone that came today and made the SAU display happen.........Runner Up Best Club is a well deserved pat on the back for all of you for making it happen :)
i am sunburnt. however thank you to troy for providing the sunscreen.... :thumbsup:
i still cant believe i won Miss New Age lol......... :D :D
i got a heap of pics, but ill post up a couple now and ill go thru the rest later and choose the good ones to post up :thanks:
Came along for a quick look. Took a few pics...
The rest are at http://photos.jay019.com/OSNA_2009-03-28/
Didnt end up staying long cause the kids were getting restless, but was good to see some real nice cars out.
Got some top ideas for the Skyline Nationals for next year (all ages bouncy castle anyone? :thumbsup:)
The SAU display was pretty nice. Wasnt too keen on that sticker covered skyline tho. lol.
Ooh, and sweet, loved the R31 GTS2! Nice bloke who owns it too.
Was an excellent day! Great effort by all to be out and about so early on a saturday morning. And a big cheers to Cara for organising the whole day, and Ruby for his world class SAU awareness speach.
Heatstroke + tired = bad..............mmmmmmmmmmk.
Was a good day... went on a wee little bit too long I reckon... was getting a little bit restless and shitty towards the end due to the heat hahaha
mayb i shoulda put my bowzer teddy on the engine :blink:
most entrants = most cash put towards event
i would have picked them aswell if i was the judges ensures it will be around next year
there plastic trophys, next time skip show and use your entrant money to buy 1 :D
i had a couple of people at the show come talk to me about the GTR. i reckon that kind of kudos is worth more than a trophy.
A few photos,, my wireless net is slower then a non educated, no teeth, crack head, mullet cut, bogan in a 6cyl N/A Carbie Forden (=ford or holden)the day after being cut off centrelink
when it improves I'll post more up. including a holden ute with purple long hair fur on the dash..lol add to the hall of shame
was an awesome day! one of the best events i have been too. around 300 cars i think it was?
Happy to take home "best presented car in club display" :blink:
Was good to meet/catch up with some fellow members who love to talk shit just as much as i do. Steve, your a f**king laugh, best gay accent ever. Trying to convince the mrs to get that 4 door 34 off ya :D
Thanks for organising again Cara, awesome day.
JJJJJJJJJJEEEEEEEEEEEEEEEZZZZZZZZZZZZZZZZZz Damo oooohhhhhhh thanks alot:)
Ill PM you a link to that 4door 34
Over & Out
Thanks for an awesome day had a great time, great job cara on organising it and winning the miss new age. looking forward to the nest one
thanks guys
Also from the missus (sara) she had a great time to :(
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
