  • Replies 2k
Go tomj!!!
I havent seen your coupe yet but be sure to let me know when your finished.Whats the go?Stock ecu/turbo etc?Let me know if you need any help/advice as ive suffered quite a bit already and am quite a bit wiser for it.
PS.I got my new sticks for the FJ,just waiting on the adjustible sprockets.
Todd
Go tomj!!!
Todd
awesome to hear. Cams should wake that fj20 nice and early now. Im looking forward to riding in and featuring it :D
Mine will be stock until it is registered , then I think it will be something like wolf 3d and turbo / injectors / gate etc R32 brakes. Basically whatever
Ant and Steve reconmend for my needs. Ive got cage already so it gives me a good base for some track work.
Begins this week. might cover it on the site.
Tom
That car is WRONG!
Hows the oil cooler hangin out the front!
Its just wrong.
i agree if you want a old school gtr then buy one don't kill a car that has its own style!!
hello from magnetic island!
chu-rulz- as you can tell i'm not at home so i'll pm you around the 12th as thats i'll be home, if you hav'nt been able to get your hands on something all ready by then!
if anyones looking or knows anyone that this might suit! www.carsales.com.au/pls/carsales/!cs_content.private_vehicle?vehicle_id=70481&current_rec=1&total_rec=1&sort_type=&make_id=5&model_id=73&badge_id=31429&search_distance=50
its not a dr but a hr with a rb20det, not a bad price!
if anyones looking then this seems like good deal though it states dr30 its a hr30, its has a link management system in control with hand set!
if its for you or you know of someone who may be interested then pm and give you all the info!!
hey people,
thought id hop onto this whopper thread too! my eyes are literally stinging after reading it all! haha that and its 2:30am haha
i just got a red & black 83 DR30 RS Coupe. mods wise it has strut brace, greddy boost relief valve, 15" watanabe's, KYB shocks and super low springs of some sort (specialy at the back haha), cat-back exhaust with huuuuge muffler (5.25" tip lol), and small Trust FMIC kit (with like 1m of piping to the inlet too haha 80s a/m stuff). oh and optional front rubber lip =]
ive had it a couple of weeks, and already got about 5000$ worth of spending planned haha big fuel pump, hybrid cooler & custom piping, some minor rust fixing and bodywork & new seals everywhere,& new rear shocks!
has 219rwhp as is on 0.9bar, but hoping will realy benefit from pump and bigger cooler (With much shorter inlet piping)
this is a good thread, got some interesting stuff from it. not much on shockies though, coz im wondering what to change mine to (thinking i stick with KYB but get some AGX adjustables?? not sure)
neway, il keep adding wat i can! haha
ARRGHHHHH WHAT HAVE THEY DONE TO THOSE DR'S!!! They are fugly!!! How could they do that to a perfectly good car!!!
TJ i am Dattoboy in IRC bro :P:D My mate is starting his as well in the next couple of weeks let ya know how he's going with it....
[ant]- welcome to this monster, good to see another rs in the red and black! what nose dose yours have? (iron mask or does it have a grill), we did have a lot of info on shockies, struts and brake upgrades but lost about 3 pages/65 posts which seem to cover all this!
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
