Yeah cool Mike...Sorta all happen in next few months, once we all have it figured!! Josh Crimmo's car *should* be 90% finished this weekend, we gonna attack it gusto and get it finished! Meh u can go HSV hunting, im going SR hunting :D:)
I just scored an email telling me to stay tuned so im assuming that things are gonna happen real soon..One can only hope
  • Replies 2k
rsx - will check the wiring, hopefully it is the only thing wrong wif it.
yeah mate i had a good look this morning i unhooked the wire from the sensor and tryed to start her no go would just kick over not fire up!!, work on this info.
the r32 wire thats connected to the sensor is blue, thats been cut at the sensor, a new plug was put on then run to the conection at the wiper motor and is spliced into a yellow with a black strip wire (there are 9 wires running into this plug and 2 are yellow) i'll confirm the colour tommorrow!
can someone help with tacho info, i know the signal running from the r32 ecu runs through a greenie blue wire, the problem is the r30 tacho has three wires, yellow blue and black, can some one let me know which r30 wire takes the signal? i'm thinking the black is earth yellow power blue signal???
i'll try to post up some pics of what my wiring looks like as i didnt do it and it looks like its all over the place, but it works!! also crimmo, those watanabe RS8 rims, what size are they as i'm looking at a set tommorro (ref to post 340 on page 14 for pic) any tips as thier wider than the hayashi's that were on the car to start with!
P.S. my car will be fin and engineered half way through next month in standard power output then once on road, rb25 turbo and unichip running the ECU she should be good for around 180-200rwkws!!
Hey rsx84, mine are speedstar RS-8 watanbe, 16x7, 16x8, paid $500 a few years ago, straight out of a container off the docks, got a bargain, they are sweet rims and if you can get them in the same size your laughin! :worship:
crimmo - to get them four spots on did you change to the r31 gts struts or did you adapt them with the standard mr30 stuff? im looking to do the 4spot converison soon and i have the 31 gts struts. anyone know of and hassles with this? and also crimmo, where did ya get that tower brace thingo (the blue thing) and how much?
also crimmo - was your car auto l24 once and did you get dragged by a trashed r30 with an rb20 down paynhem rd? (a while ago now)
haha yeh man! that was me!! small world huh!
With the R31 struts they should be floating disk from memory and you can slide on R33 non turbo disks, and R32 turbo 4 piston calipers, you may need brackets for the calipers, you may not too, but thats easy! :worship:
I bought the strut brace off a mate who bought it from some guy on performance forums, its adj, cusco, but i didn't notice a huge improvement as the thing f***ing sticks like glue with the coilovers anyway :cheers:
As I said I'll be down for a cruise just gotta get my little bit of damage fixed and front end back on. As would Tom, corey and Aids???? maybe mick if he buys it no doubt. We could get some decent numbers out with all decent cars. Show what old school skylines can do. A couple of weeks till my new clutch will be in. How long are others expecting to be off the road for? Shane not much longer now? crimmo?
shold be driving in 3 three weeks if all goes to plan! :worship:
bargain and then some, i'm paying $990 for 15x7,15x7.5 but they are sick and fill the guards like a glove, with the 3 peice bolts they look so much better than the cast sets you can get. fitted the strut brace today, i've got around 2mm of play before the inlet manifold hits the brace so might look into a stabalizer shock for the engine? whats the gap you have with your cusco??
wiked!
where do i get the brackets or is it a custom, make your own job?
RSX84,
I have a set of 5 spoke MONZA Racing Rims for my HR, 16 x 8 & 16 x 7, 3 piece, +38 offset and they fit under the rear just great. Cost me $500.00 with tyres, good enough for rego/engineering.
After engineering, I am going to put a 20mm spacer onto the front hubs and get new inner rims made to widen the fronts an extra 1 inch inwards, making 8's all round, shod with Yokohama A-008 RS II's or A-032's or Dunlop D01J's, street legal racing tyres, 245/45 x 16.
Should make it stick like sh#t to the proverbial blanket.
My coilovers have 400 lb/in front springs and 330 lb/in rears, plus 25 mm front sway bar and 24 mm rear mounted on urathane bushes and semi rigid link pins made from 10 mm rose joints. The rear cross member and diff support are mounted using urathane bushes, all custom made by Noltec in Sydney at a cost of about $400.00. Lower control arms still have standard rubber bushings.
Up front I have adjustable caster bars and urathane bushes, lower control arms have standard rubber bushings on inner mounts and have replaced the ball joint outer with adjustable rose joints making camber adjustment infinite, with the help of the adjustable strut top on the JIC's.
I may have to change the spring rates after final weighing, more closer to completion, to create better balance between front and rear, with me and about half a tank of fuel in the car.
RSX84,
just thinking with your rb30/25 conversion will the brake set up your engineering it with be enough as thats a big power to weight ratio?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
