well when i mounted my vg30 i had to 'tweak' the oil line , cant remember which one cause it was hitting something.
as for the tacho yeah i read somewhere (very specific arent i) that u need to put a resistor in somewhere to alter the signal
may have been PF...."how to recalibrate r31 speedo" :P or sumthin
  • Replies 2k
get this, i posted ages ago about my diff and what the diff was doing??? after a week of f#$king around with it, i find out its the hand brake thats the problem, the passenger side cable has been crushed and when you put it on it stays on so while driving i've had the rear brake on, doh, so now she goes alot harder!!
a mate at work told me about the need for speed forum the other day as someone there has created a dr30 to race in the pc version but found this as well. onyone know the side skirts at all?
The body kit is from JENESIS, www.r30.co.jp the front bar is identical to the one I have here in OZ that I plan to make in small numbers. The side skirts cost an arm and a leg to get here to OZ, so that moulds could be made to reproduce them locally.
The rear view car has the STOCK DR30 body kit, found on most RS-X models, same as the Peter Jackson cars had in the late 80's.
I am making enquiries on how to get them, or maybe modifying R31 or R32 ones to fit, so that I could market a complete body kit for R30 Skylines, strictly on a limited basis, after all, we don't want them all the same. :ghost:
RSX,
They look a little different to the JENESIS skirts.
Do you remember where you found the pic?
If so! email him/the site and ask some questions, or PM me the site and I will do the chasing for you. :ghost:
ALL R30 Parts are interchangeable. The DR struts bolt in, same lower ball joint & control arm, guards, bonnets, etc, everythings the same, that's why we are chasing them.
The only changes are coupe doors don't fit on sedans, unless you want to cut them in half, but if it comes off a coupe, HR, or DR, it don't matter, if it's sedan, fits another sedan. etc, etc, etc.
hey guys, im thinking of putting together a 30's page? what you reckon worth it or not?
i mean i am going to set up a page for my car regardless, but then i was thinking there is no definitive r30 info resource....
if you guysthink it'll work, let me know and i'll start getting info etc
cheers
cheers
are you talking on this site (photo gallery) or outside, as a few sites have been started but theres no great sorce of info out there but if you have the time to go back through this thread you may be able to get some great mod info!! i'd also be up for starting a photo gallery here through get us all somewhere to put pics!!
cheers
Well if your doing one up for your 'line, you might as well do up a r30 site, as there are very limited english sites dedicated to the mighty r30's, particularly ones with useful info..
Quick note though didnt we lose a lot on this forum due to some computer glitch. As if i remember it was quite useful.
Good luck
Good luck
mostly suspension stuff but there seems to be even better info on this here now! if you do a google aus search you can get a few sites but most are for sale sites or small write up in larger stories, any info i've found is years old and has'nt been updated in the last few years at least!!
http://www.jaustech.com.au/general.htm
http://homepages.tig.com.au/~robs/kevspage.htm
these are the only sites in english that i got any info from, the rest are japanese and when translated make even less sence!!!
Robs/Kevs page is fairly informative and Rob's car is still under development. And the site will probably be upgraded when it goes back on the road again, but he hasn't done the brake conversion we have on this site, he hasn't done the body conversions, or suspension, mostly his mods are of standard available parts as opposed to Jap import TRICK BITS.
AND >>>>> SIDE SKIRTS >>>>> Might have the Jenesis ones here in a few months, so we can see what I can organise for copies.
RSX,
Your Avatar, IS IT YOUR CAR????
RSX,
yeah its my car, pics taken around three months ago in the parking area of my units!
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
