  • Replies 2k
Ghostrider, because it looks sooooooooo much better than the TI grille which is very ghey
Ta for the info, I figured that since the honeycomb one is also on the PNV's that it must be from the TI's
I went through a whole lot of Jap pics and decided that I like the 3 slat grille the most. Also saw a few lower front spoilers I really like, but getting them aint gonna happen.
Does anyone have any idea on where to get some bolt on flares from? And do the Japs cut out the inside of the guard when they fit the flares? I know that HDT did it with the VB's or VC's that had the flares
I'd like the flares and I could get my rims widened
it requires you to send the crosmember and trailing arms over to them, not bad though
I just contacted them by email & BAZ replied, ONLY FOR 510/1600's, doesn't know of any ARC's for R30's.
Can your info be confirmed?
anyone in adelaide got a spare black thingo that goes above the rear bumper and under the lights. its like a continuation of the mouldings around the sides...
Good luck, I search Sydney wreckers for them all the time. If they're not damaged from accidents, they're bubbling from rust, from the backing and clips.
In about 5 years I have found 3 that are perfect, and those 3 are now drowned in fishoil.
In your search, be aware that 81/82 are different to 83/85.
spewin
These are available through genuine Nissan parts for $112 Trade price..... I reakon thats a good price if your in need of one!!
That's an excellent deal, considering they want $8-10 for a wheel stud.
hm........ dunno if my car has that
Certainly Has!!!! they all do!!!!
Coupes, Sedans, Hatches, Jap imports & Aussie delivered, they all got one.
To you it may appear to be part of the rear bar, but it certainly is there.
Check Thumbnail!
If you look closely on the thumbnail, just left of the bottom left corner of tail light, you will see a bubbly section. THIS IS RUST in the support bar and it looks UGLY if not FUGLY and the clips rust and break.
GOOD 2nd hand is hard to find and NEW might be a better alternative.
Mike,
Is yours the same as pic?
ADJUSTABLE REAR SUSPENSION
Baz from DatSport in Adelaide will modify or make up the jig to make the R30 Suspension FULLY ADJUSTABLE, if we can get 8 people willing to get the job done.
DO WE HAVE EIGHT (8) on this forum that want's the job done????????
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
