COILOVERS?????
You all want to modift to use S13.
Why not make up, do the mods to your own R30 struts (front) only need to find a machine shop that will machine off the existing spring seat. The thread kit & nuts can be bought through Wideline or Noltec direct for about $400.00. If doing it this way, you can cut down the strut case to suit R31 inserts, that are about 40mm shorter, therefore the damper piston stroke doesn't alter when lowering.
Rears can be made up using R31 rear shocks, they are 32mm shorter.
  • Replies 2k
1983 MR30 sedan.318000km.
any easy way to replace a inner CV boot.
As far as I know, they are NON SERVICEABLE, But! the workshop manual says it is possible, so email me on [email protected] and I will scan and send you the pages concerning this procedure.
i went with the hybrid as i got it for $600+postage brand new, i read on the powerdigger site that the hybrid 600x300x75 intercooler had "0.5psi loss at up to 40psi" and can cool around 500hps' worth of air flow. hope that helps!! had the piping made from 2 1/2" press bend mild steel for $450 installed, all up about $1100 fitted..
matt did you get the super monster? when did you get it from at that price, and is it a 'genuine' hybrid? don't know if that makes a difference just interested to know.
COILOVERS?????
hmm im quite interested in the R31 strut case thing, as my front is a lil too high compared to the rear even with lowered springs, not going full coilover, just swapping them.
yep.. bar, plate and fin super monster cooler "genuine hybrid" bought it about 8 months ago on e-bay for $600 as powerdigger is the offical surplier but wanted $800 for the 600x300x75mm cooler. ended up being a place here on the gold coast that were selling them...
']the S13 rear coilovers fit up all good except they are either 2 hole at the top at the back, whereas DR30 are 3. basically u have to drill an extra hole to line up the S13 coilovers at the top. pretty simple job though. just stick one thread in an existing hole, then drill a one that matches up on the other side. i havent done this to my car but todd with DR30 on these forums has, im sure he will pipe up soon to confirm what i just said :D
i mite be interested in a shirt depending on it's design and price i guess.
Just been studying a set of S13 coilovers.
Can't see how the fronts are anything like EASY conversion.
But rears look OK, but has anyone thought of changing the tops, swapping the stock R30 top for the S13, then NO DRILLING required.
Would this work???
i actually hadnt thought of the tops to be honest.
but the rest of it would be easy enough i guess anyway doing full coilovers. i mite do that one day altho i like my susp as it is now (tho the front could be a bit lower it sits pretty flat coz matched springs from japan so its okay really)
as far as the coolers go, i would agree with nowehre for $350. theres a few group buys on forums with them around 400-450 if u get in at the right time and are willing to wait in some cases, otherwise theyre all around $600 or so that i have found for 600x300x76 Core Size bar and plate coolers. Most i see for this price tho arent genuine hybrid stamped coolers, though it makes no difference apparently they come from the same place. i had a non-stamped big Hybrid in my last car (S13) and it was great, had no problems with it at all, just didnt have Hybrid on the top of it!
i got my one through the ModYourCar.com website. they were on special for $495 + postage. not sure how much they are regularly, i think around $550 but then u need $50 or so for postage, so you guys over east (coz MYC.com perth based) probly be around $600. *shrug* or find a group buy if u can !
edit: and i dont work for them or nuthin haha i just ordered one a couple of weeks back to go in the DR thats all, so i had a hunt around forums and websites for them. though i dont use EBay so i didnt check there. just this site i got mine from was the cheapest i could find at that time ignoring group buys!
just on that, theres a guy on SilviaWa.com forums under Shop, S1x Shop, trying to organize a group buy of coolers trhough modyourcar.com, if they get 10 or more people then its $450 each for the coolers.
if theres a few of u interested mite be worth it to get one to ur door for round $500 if enough pple join it *shrug*
to replace the CV boot you need press and it looks like a big job.the boot is torn from an exhaust thats fell off.
The CV on My R31 passage are getting noisey on a long drive.
probably get replacments from a wreck .Are R180 R30 driveshafts interchangeable with EARLY R200..I had a cone type idea that allowed you to slide a boot over without pulling the shaft apart,but cant find anyone with these at the moment.
I have R30 coils and R31 struts on my R31 passage[iRS],the 5 link struts are 25 mm+ longer bush to spring seat, than the IRS.hatch and sedan are also different.
R30 is my current work car.purchased for the tyres.It has more go than the bluebird and more room but it is no ser3.Got a 910 LD20T sitting in the shed,find some R30 LD28 bits and get it running.
I have been quoted under $450.00 for cooler with core size 700 x 270 x 65.
Is the thickness all that critical, compared to the front surface area, where the air gets to it.
I believe 600 x 270 would be the perfect size for R30's, as you wouldn't have to cut the guts out of your lower spoiler to accomodate it.
i got mine from a shop here in sa 750x300x60 for 750 with end tanks where ever i wanted them. i thought i was a good deal
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
