  • Replies 2k
Oh yeah did anyone read the latest HPI mag as it has a dr30 in the SA drift section, not anyone from here is it? or know of it? bugger about the front, lol.
If its grey over black with custom number plates, thats Tom, pretty nice setup when it comes to performance too
Thats Tom in the last issue from the JMS drift day. But I believe that would be mine in the new issue from the Club PSI drift day. But from the front end bit I dare say it's mine your talking about, It looks even worse these days. I still haven't seen the issue but been told theres a photo in there.
Hey guys, i'm looking for a specifications sheet on the DR30 and HR31, any idea's? i would really appreciate it as im writing specifications for every skyline made, and i'm up to the DR30 and HR31, thanks.
-Dallas.
Sweet Josh, looks good
I'll have to get some new pics of mine up sometime, changed a few things so it looks different now.
Crimmo, any chance of getting a look at how you did the coilovers and brakes sometime? (I was the guy with the R31 the night you locked the keys in the R33 at BP Gorge Rd, Andrews friend)
@@@@@ POLO SHIRTS @@@@@
Shirts are ALL GO!
Anybody got any input, towards what they should say or look like.
My ideas,
SAU Logo on the front and on the back 2 cars angled towards each other with R between the cars and 30 below between the fronts and maybe SKYLINES across the bottom, or Skyline Owners.
Will knock up a couple of pics and post them.
Something else though, if we use the word "Nissan" or "Skyline" we/I have to get permission from Nissan.
Cheers
is MR30 hatch Front Left Suspension the same as DR30????
All R30 suspensions are interchangeable, DR, HR, MR.
### BUT ###
The brakes & mounts are different.
The HR & MR have the stock 250 x 18 front disc rotors and DR has 274 x 22 and the HR & MR mounts are only 3.5 inches between the centres and DR is 4.0 inches.
Answer to your question is yes, but you have to change both along with the smaller brakes.
-Dallas.
What specs are you looking for?
I can give you body dimensions, road clearance, brakes etc, but what are you looking for?
The DR was just a comp version of MR/HR.
got it a few days ago and if it is you then i guess your looking to get a new front bar!! these a caption with the pic that states " wheres my front mount, has anyone seen my intercooler" along those lines, bad luck mate. at least the rest of the car looks sweet..
what do they do? electronic valves?
put it this way the control switch has a hard or soft setting! was more popular in the r31 gts-x and gts-r. some sort of solinoid sits at the top of the strut...with mine one of the solinoids was rusted badly...
ghostrider: do you have the control switch is i have one that can go to the same home! free as well (i'm not using it).
Shirts are ALL GO!
My ideas,
Cheers
what do you think of this on the back " i got that car so i could get this t-shirt" :jk:
its all good to use the SAU logo though isnt it? if so what if that was on the front with a outline of an r30 underneath (small) Then on the back your looking at a 2door and 4door facing each other 3/4 veiw, put at the top of the back of the shirt, then under that something like "R30 Division/Skylinesaustralia.com" if we went that way then having nissan/skyline permission wont be needed if we have permission from skylinesaustralia.com?
OK Guys,
This is our FIRST prototype, What do you think?
Combines a few ideas, come back to me with your thoughts.
Cheers
Hey all, interesting thing happened to me the other day. I was just driving along kind off sensibaly (Kind off), when all of a sudden, my car was making a horrible grinding noise from under the bonnet. Very soon after (I pulled over as soon as i could) it had overheated.
The problem turned out to be the water pump, the drive shaft had sheared in three places.
Just thaught that it was kind of odd, breaking in thee places.
Anyhow, if anyone has, or knows of a DR30 for sale, i am interseted.
Also, what is the going price for one in good nick, with some mods?
I have possibly found one for $13000, it had a bunch off trust gear, (BIG turbo, dont remember what model) front mount intercooler, three inch exhaust 50mm wastegate etc.) Also coilovers, and it is an ironmask. and four door. Build is '85'.
Unsure of km's, waiting on more info.
Is $13000 exxesive?
Any help apprecciated, Mick.
Ohh yeah, if anyone has a non injected skyline (L series motor) I have an injected heead, complete with ECU) if your interested let me know. (Also a auto trans (out of Aussie R30))
Cheers again, Mick.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
