  • Replies 2k
Oh yeah did anyone read the latest HPI mag as it has a dr30 in the SA drift section, not anyone from here is it? or know of it? bugger about the front, lol.
If its grey over black with custom number plates, thats Tom, pretty nice setup when it comes to performance too
Thats Tom in the last issue from the JMS drift day. But I believe that would be mine in the new issue from the Club PSI drift day. But from the front end bit I dare say it's mine your talking about, It looks even worse these days. I still haven't seen the issue but been told theres a photo in there.
Hey guys, i'm looking for a specifications sheet on the DR30 and HR31, any idea's? i would really appreciate it as im writing specifications for every skyline made, and i'm up to the DR30 and HR31, thanks.
-Dallas.
Sweet Josh, looks good
I'll have to get some new pics of mine up sometime, changed a few things so it looks different now.
Crimmo, any chance of getting a look at how you did the coilovers and brakes sometime? (I was the guy with the R31 the night you locked the keys in the R33 at BP Gorge Rd, Andrews friend)
@@@@@ POLO SHIRTS @@@@@
Shirts are ALL GO!
Anybody got any input, towards what they should say or look like.
My ideas,
SAU Logo on the front and on the back 2 cars angled towards each other with R between the cars and 30 below between the fronts and maybe SKYLINES across the bottom, or Skyline Owners.
Will knock up a couple of pics and post them.
Something else though, if we use the word "Nissan" or "Skyline" we/I have to get permission from Nissan.
Cheers
is MR30 hatch Front Left Suspension the same as DR30????
All R30 suspensions are interchangeable, DR, HR, MR.
### BUT ###
The brakes & mounts are different.
The HR & MR have the stock 250 x 18 front disc rotors and DR has 274 x 22 and the HR & MR mounts are only 3.5 inches between the centres and DR is 4.0 inches.
Answer to your question is yes, but you have to change both along with the smaller brakes.
-Dallas.
What specs are you looking for?
I can give you body dimensions, road clearance, brakes etc, but what are you looking for?
The DR was just a comp version of MR/HR.
got it a few days ago and if it is you then i guess your looking to get a new front bar!! these a caption with the pic that states " wheres my front mount, has anyone seen my intercooler" along those lines, bad luck mate. at least the rest of the car looks sweet..
what do they do? electronic valves?
put it this way the control switch has a hard or soft setting! was more popular in the r31 gts-x and gts-r. some sort of solinoid sits at the top of the strut...with mine one of the solinoids was rusted badly...
ghostrider: do you have the control switch is i have one that can go to the same home! free as well (i'm not using it).
Shirts are ALL GO!
My ideas,
Cheers
what do you think of this on the back " i got that car so i could get this t-shirt" :jk:
its all good to use the SAU logo though isnt it? if so what if that was on the front with a outline of an r30 underneath (small) Then on the back your looking at a 2door and 4door facing each other 3/4 veiw, put at the top of the back of the shirt, then under that something like "R30 Division/Skylinesaustralia.com" if we went that way then having nissan/skyline permission wont be needed if we have permission from skylinesaustralia.com?
OK Guys,
This is our FIRST prototype, What do you think?
Combines a few ideas, come back to me with your thoughts.
Cheers
Hey all, interesting thing happened to me the other day. I was just driving along kind off sensibaly (Kind off), when all of a sudden, my car was making a horrible grinding noise from under the bonnet. Very soon after (I pulled over as soon as i could) it had overheated.
The problem turned out to be the water pump, the drive shaft had sheared in three places.
Just thaught that it was kind of odd, breaking in thee places.
Anyhow, if anyone has, or knows of a DR30 for sale, i am interseted.
Also, what is the going price for one in good nick, with some mods?
I have possibly found one for $13000, it had a bunch off trust gear, (BIG turbo, dont remember what model) front mount intercooler, three inch exhaust 50mm wastegate etc.) Also coilovers, and it is an ironmask. and four door. Build is '85'.
Unsure of km's, waiting on more info.
Is $13000 exxesive?
Any help apprecciated, Mick.
Ohh yeah, if anyone has a non injected skyline (L series motor) I have an injected heead, complete with ECU) if your interested let me know. (Also a auto trans (out of Aussie R30))
Cheers again, Mick.
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
